H and F series overbore question...
Old Aug 26, 2002 | 10:08 PM
FastechAccord's Avatar
Default H and F series overbore question...
Some guy on the Accord forum posted he had his f series bored .20 over. I thougth these motors didnt come with iron sleeves.???? Can you bore or even hone these blocks since h and f series blocks are designed alot alike?
Old Aug 26, 2002 | 11:53 PM
DLB1994's Avatar
Default Re: H and F series overbore question... (EvoAccord)
it matters if he got forged pistons or cast pistons
Old Aug 27, 2002 | 08:15 AM
Default Re: H and F series overbore question... (DLB1994)
He used the Race Engineering pistons and crower rods. But how do you bore a motor with no iron sleeves??
Old Aug 27, 2002 | 08:27 AM
DLB1994's Avatar
to put forged pistons in any f or h engine u got to re-sleeve it
and u can bore it how much u want then
Old Aug 27, 2002 | 10:50 AM
sgT's Avatar
sgT
either that or he had .25 overbore FACTORY pistons.
Old Aug 27, 2002 | 12:05 PM
Is it possible to just replace the factory pistons with forged pistons and not hone or bore the block? Will you get a good seal for the rings?
Old Aug 27, 2002 | 01:21 PM
niedejb's Avatar
If you can clean up the cylinders and stay within the F22 oversize bore limit (.25 over...85.250-85.260mm, .50 over...85.5-85.510mm).
Per honda factory manual...Reboring limit .050mm max
9341civic
Oct 1, 2006 04:24 PM
9341civic
Jul 4, 2005 05:55 AM
9341civic
Jan 1, 2005 10:26 AM
AutoLab
Aug 6, 2004 04:50 PM
