obd2 gsr harness in a obd1 gsr???
hey guys i have a couple things i need cleared up for my build that i thought you guys could help with. i have a 94 gsr which is obd1. i bought a obd2 gsr swap out of a 96 integra gsr to put in my car. i know that i need to get an obd1 ecu but i tried plugging in the harness into my car and all of the plugs worked except for one and i was hoping that someone might know what this plug is.
the plug that doesnt fit is the smallest one on the passenger side. the plug coming from the car has two wires coming from it and the one from the engine harness has three wires. can anyone tell me what this plug is??
will have pics up soon if that will help. thanks and please bump if viewed.
and then swap the injectors, dizzy and I believe the Voltage Regulator Module on the alt also has a different connector , then it should be pretty much plug and play there may be a couple others that you may need to splice or change
saleensolution
Oct 25, 2005 04:42 PM
gezer
Aug 26, 2004 10:42 PM
