What are those sounds from the front??
Hey guys, I have a 94 Integra GSR and in Dec of last year I hit a curb going 10-15mph in the snow. Since then noises gradually started to get louder whenever I braked and slowly turned from parking spots. It got really loud so I figured it was the CV axle on the right because it was ripped open and grease was all over the damn place, so I replaced that.
But the "knocking" sounds are still there and I looked at the drivers side CV axles and it looks fine. It sounds like if you were in the attic and the floor was old a sshit and making noises.
What should I do to fix this problem?
I have the drivers side axle, but I dont wanna replace it if its still good, I can return it and get my money back, but I just wanted to see what you guys thought. Thanks.
Yeah, I'll check. Weird because i had it inspected at Firestone but they said the axles needed to be replaced and now they are and they still making noises while I'm braking. I couldnt see anything obvious.
check your brake rotor? driver side mount if the busing is starting to come off. makes sure all nuts and bolts are secured in the suspension fork and control arm. also make sure you dont have blown shocks/strut.
boost4life1
40
Mar 26, 2024 08:26 PM
killerboots
May 1, 2003 06:29 PM
