****MEGAN RACING **** SUPENTION, LCA'S, EVERYTHING
http://www.facebook.com/TNAAUTOSPORTS
http://www.tnaauto.com
hit me up .... i have alot of parts just ask me what u need an ill pm u back an if u can bump plz
FOR ALL HONDA'S/ACURA
TELL ME WHERE U LIVE AN ILL GIVE U SHIPPING COST
full megan street damper kit
honda accord 2006 cat back moe style
honda s2000 catback moe style
universal moe muffler tip
CAMBER KITS
SPRINGS
Coilovers - Regular
Coilover Damper Kits - Track Series
Acura RSX Base/Type S 02+
Honda S2000 1000
Coilover Damper Kits - Street Series
HONDA'S /ACURA'S /TL /CL /ACCORD / FIT /TSX / NSX 980
H- Braces
CIVIC/INTEGRA
Honda Civic 01-05/Si 02-05 / Acura RSX 02-06 / Honda Civic 06+ / Honda Civic 06+ W/down pipe
Interior C-Pillar Bar
Rear Lower Tie Bars
Rear Upper Strut Bars
[IMG]http://www.meganracing.com/uploadImage/regular
/ACCORD%2094%20FRONT%20UP%20BLUE%20X500.jpg[/IMG]
Race Spec Front Up Tower bars
Honda Civic/Acura Integra Rear Lower Control Arms
Honda Civic Si EP3 02-05 / Honda Civic 01-05
Our most recent addition to our expansive coil-over kit line up, the EZ STREET coil-over line up is aimed towards the more budget oriented enthusiast to offer the most basic essentials from an after-market coil-over setup, yet makes no compromises for quality and performance.
Features:
- Spring Rates: 10kg Front and 5kg Rear
- 15 Levels of Adjustable Damper Strength
- Aluminum Brackets paired with rubber inserts
- Rubber Dust Covers
- Adjustable Ride Height
- Conservative Spring Rates
- Single-Cylinder Design - monotube
- All coilover damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
COST 680 shipped in the US
APLICATIONS
Honda Accord 03-07 / TSX 03-07
Honda Accord 08+ / Acura TSX 09+
Honda Accord 90-97
HONDA ACCORD 98-02/ ACURA CL 98-03 / ACURA TL 98- 03
HONDA CIVIC 88-00
ACURA INTEGRA 90-01
HONDA PRELUDE 92-01
HONDA S2000 00-09
megan racing street damper kit
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 levels of damper force adjustment, separate spring perch height and shock length adjustment allowing you to retain full suspension stroke and to fine tune your suspension characteristics. These damper kits are then perfectly matched with front and rear Pillow Ball upper mounts, including camber plates integrated with the upper Pillow Ball mounts on strut-type suspension applications.
SPECIFICATIONS & FEATURES:
APPLICATION:
Honda Civic 1992-1995 EG6/1996-2000 EK9
Acura Integra 1994-2001 DC2/DC4
Honda Civic/CRX 89-91
Acura NSX 1991-1999
Acura RSX Base/Type S 2002-2006
Honda Civic 06+ (including Si models)
an more check meganracing.com
SPRING RATES:
F: 62mm ID; 180mm length; 12 kg/mm
R: 62mm ID; 180mm length; 6 kg/mm
DAMPER SPECS:
F: 95mm stroke; 190mm length; A2 valving code
R: 95mm stroke; 200mm length; A1 valving code
- 32 Levels of Damper Force Adjustment
- Pillow Ball Upper Mounts
- Rubber Dust Boots
- Aggressive Spring Rates
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coil-over damper kits come with 1 year manufacturer-defect warranty.
COST 880 shipped in the US
megan street on my tsx
CAMBER KITS
SPRINGS
Coilovers - Regular
Honda S2000 1000
H- Braces
CIVIC/INTEGRA
Rear Lower Tie Bars
Features:
APLICATIONS
Honda Accord 90-97
HONDA CIVIC 88-00
ACURA INTEGRA 90-01
HONDA PRELUDE 92-01
HONDA S2000 00-09
APPLICATION:
Acura NSX 1991-1999
SPRING RATES:
DAMPER SPECS:
- Rubber Dust Boots
- Aluminum Brackets
myspace.com/tna_autosports
CAMBER KITS
SPRINGS
Coilovers - Regular
Honda S2000 1000
H- Braces
CIVIC/INTEGRA
Rear Lower Tie Bars
