Honda S2000 Honda S2000
Help with diagnosing weird idle drop
Old Sep 3, 2009 | 01:53 PM
jsull.'s Avatar
Default Help with diagnosing weird idle drop
Hey guys I'm looking for someone that can help me diagnose whats going on with my car. I recently installed a Blox Racing Throttle Body and Block Racing Thermal Intake Manifold Gasket. Before I did this install everything was working perfectly on the car but after I did the install I have been having this one issue with the idle, when I'm coming out of gear and coming to a stop the idle doesnt drop right away and it takes a second for it to drop to a regular idle.
I did adjust the TPS Sensor to the OEM Spec and still have had no change.
The throttle body I'm using is the Blox Racing Tuner Series 68mm P/N BXIM-00210.
I also port matched the throttle body housing on the intake manifold as well.
IDK if its the throttle body causing this issue or if it may be the thermal intake gasket.
Its on a 03 S2000
Thanks in advance for any help you can give me!!!
Gho$t
Nov 10, 2009 10:26 PM
Mr_Moos
Mar 8, 2007 02:25 AM
90AcuraIntegra04
Feb 4, 2006 02:18 PM
se93
Dec 28, 2003 09:21 AM
