What size Injectors should be used?
Old Sep 3, 2009 | 01:10 PM
phoshyzzle's Avatar
Default What size Injectors should be used?
Hey h/t. I just finished putting my motor together and i was wondering what size injectors would be right for my set up. The motor is a gsr built with:
LS crank / Shotpeened LS rods/ arp rod bolts
p30 pistons
crower stage 2 3/4 race cams
supertech valve train
skunk2 intake manifold
blox 68mm throttle body
hytech replica header
2.5 exhaust no cat
chipped p72 (tuned with crome pro).
I was able to get my hands on RC 370 cc injectors but someone told me to go with 440's. i personally thought 440's would be too big. all opinions would be greatly appreciated.
Old Sep 3, 2009 | 01:40 PM
:TEAL:'s Avatar
Default Re: What size Injectors should be used?
just use the 370s you have they'll work fine
Old Sep 3, 2009 | 01:46 PM
OH_1fstgsr's Avatar
I agree.
I am running 370's now. NO issues or trouble.
Old Sep 3, 2009 | 01:59 PM
1.5Slowmatic's Avatar
seeing as how 370's can support well over 230hp why is there even a question here? I highly doubt your build will make that much
Old Sep 3, 2009 | 09:43 PM
honda-will's Avatar
If you are tuning it just use the stock injectors they are good till about 200hp which you won't quite make.
bootlegtrader
Jun 23, 2005 09:14 PM
99skunkedSi
May 1, 2005 05:07 PM
b18c-rDC2
Oct 22, 2002 01:32 AM
bikeboy80
Sep 18, 2002 02:24 PM
