THINKiNG ABOUT GOIN F HELP!!
Old Sep 3, 2009 | 09:13 AM
G23ECKO's Avatar
Default THINKiNG ABOUT GOIN F HELP!!
Sooo for a couple of weeks now I been ready about all motor f builds and I want to give it a try my self, so if any of you guys build any f motors before and what did it put down and I'm talking about the soch f motors like F23 and. F22 witch one would be better .. Thanks for the help
Old Sep 3, 2009 | 09:19 AM
G23ECKO's Avatar
Default Re: THINKiNG ABOUT GOIN F HELP!!
Bump... I hate doin this from my phone
Old Sep 3, 2009 | 10:34 AM
PirateMcFred's Avatar
I've got a DOHC F-series and made 200whp and 184wtq for very cheap using a lot of OEM parts and cheap shelf parts. If you want to do it with a SOHC F22/F23 then you'll pretty much have to go with a Webcams or Bisimoto cam and that's one of the 5 most expensive custom components:
$850 F22 header (from Bisi)
~$1000 ported head (IIRC done through Portflow)
>$500 Bisi cam/valvetrain package
$500 pistons
$300 F22 rods
Be prepared to spend about $750 for custom rods for the F23 as they are unique.
Of course that's if you're going for high power. You can save a lot of money if you use OEM parts and a DC header etc. Otherwise there are few people that have made 200+whp on a SOHC without juice or FI.
Old Sep 3, 2009 | 12:20 PM
:TEAL:'s Avatar
ive read that the sohc f22 head works great
Old Sep 3, 2009 | 02:53 PM
teefunk01's Avatar
$500 pistons
$300 F22 rods
cheap? lol baaaaalllin
Old Sep 3, 2009 | 05:43 PM
My build was less than $1000 total slapped together. I meant that if he wanted to get more than 200whp he'd have to start looking into custom parts.
Old Sep 4, 2009 | 02:22 AM
G23ECKO's Avatar
That's no were near cheap lol... But I'm just trying to make about 200 whp something to have fun with ,witch one should I use the f22 or the f23 ? And yeah I know I'm goin to try to by a few bisimoto parts I seen them put in work with the soch's
Old Sep 4, 2009 | 02:27 AM
G23ECKO's Avatar
But thanks a lot for the info people
Old Sep 4, 2009 | 06:14 AM
While I've not seen it done you can use an F23 block, $400 87mm Forged K20A shelf pistons with a 3cc dome and no wrist pin offset, a cam/cam gear/VT package from Bisimoto, some 370+cc injectors and tuning should get you near 200whp.
My build was 2,307cc 11.7:1 compression 215˚ duration @ .05" .451" lift IN/EX with stock Honda parts and a DC header w/ 2.5" collector into a 2.5" exhaust and after a bit of tuning I got 200. My biggest expense was the cams/gears/vlavetrain.
Dyno (blue line):
http://i29.tinypic.com/260d2md.gif
If you have a decent local performance shop you can use OEM 86.25mm K20A pistons in the F23 but you need to rotate the piston 180˚ in the bore and make sure that you have intake valve clearance. If you don't have enough clearance then you need to machine the pistons' "exhaust" valve pockets deeper.
-P
Old Sep 4, 2009 | 11:12 AM
robfrmny21's Avatar
whats good ecko let me know when i can help u with your build i got yu
Old Sep 4, 2009 | 11:46 AM
G23ECKO's Avatar
Can I put the k20 pistons with out puttin the h22 head? Yo rob you all ready know I want to start next week on the build. Once I find out witch block to use......
Old Sep 10, 2009 | 06:50 PM
mjlafferty7's Avatar
need help too...wanna build it moderately and put a low boost on the stock f23 motor, maybe 10 pounds. what parts should i put in the motor before putting a t3 on?
Old Dec 7, 2009 | 03:47 PM
BlkChryKord's Avatar
Dyno (blue line):
I'm hoping to have this setup in the near future. I've already got everything but the bisi springs/retainers. Hoping to get close to 200whp/200w lb/ft
Old Dec 9, 2009 | 12:52 PM
Sales@Bisimoto.com's Avatar
The F22 would be my suggestion.The flow properties of the head are much better and there are more parts readily available for you
Let me know what Bisimoto parts you are interested in and let's see what we can work out
Hit me up for those springs and retainers
Old Dec 9, 2009 | 12:57 PM
michaelprice83's Avatar
F22 or F23 either way you're doing something pretty unique. I'd definitely recommend you go "F" yourself.
Old Dec 13, 2009 | 05:56 AM
Gold DA9's Avatar
damn it, i want to build f22. I got one sitting in my driveway in a accord.
Old Dec 13, 2009 | 04:40 PM
Turbowa's Avatar
you could always go SOHC hybrid F22a head and F23 block. With mostly stock parts and some custom stuff from bisi I was able to put down over 200HP and 157lb/tq. If I step up to a 3" exhaust there is alot more there. The current exhaust is an RS-R exhaustmag. Its only about 2 3/8"
hondasquadup
Dec 9, 2015 11:12 AM
bama.camo
30
Feb 28, 2014 08:37 AM
malubawla
Feb 16, 2006 12:05 PM
laughinxxx
Aug 2, 2003 10:05 PM
