Tach in a 91 Civic
Old Sep 3, 2009 | 07:58 AM
91CivicD15's Avatar
Default Tach in a 91 Civic
hey everyone, i got a 91 civic dx hatch and just bought a 91 civic si hatch gauge cluster. i was assuming it was a plug a play like the posts that i just read in here but the tach does not work. everything works except the tach. anyone got any ideas?
Old Sep 3, 2009 | 08:27 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Tach in a 91 Civic
Would seem that your tach in the new cluster might be bad.
I believe every CRX/Hatch/Sedan came wired for tach no matter what trim.
Swapping clusters should have done the trick for you... well, unless your tach wire has broke somewhere.
Make sure you have that blue wire going to the tach location.
If you know how, do a continuity check with the blue wire on the distributor.
Also - Is the check engine light always on?
Old Sep 3, 2009 | 08:29 AM
91CivicD15's Avatar
Thanks man ill try that. is there any other issues people might know it is?
Old Sep 3, 2009 | 08:30 AM
4drEF's Avatar
Keyboard Humorist
"Also - Is the check engine light always on?"
Old Sep 3, 2009 | 10:34 AM
91CivicD15's Avatar
the check engine light is not on
Old Sep 3, 2009 | 11:08 AM
the_asteroid's Avatar
I would bet on a bad tach, they're pretty easy to screw up. If I remember right the tach alone is pretty easy to replace without replacing the whole cluster, it just has a couple of screws on the back. The screws double as the electrical connections for the tach so you may want to make sure those are tight and none are missing. But do check out the wires and connectors at the distributor, really just look for anything that looks like it's been tampered with or doesn't look like it's in good condition. There's really not many reasons that there wouldn't be continuity between the tach and the distributor.
Old Sep 3, 2009 | 11:23 AM
91CivicD15's Avatar
will check that also. thanks for the help guys
MYGODREPENT
Mar 11, 2010 06:04 PM
DOHClessEF-9
Dec 29, 2004 09:02 AM
ZCcivic91
Oct 7, 2003 09:58 PM
element_1one
Jun 16, 2003 08:50 PM
