Has anyone ever done this set up?
I am new to honda-tech and was wondering if anyone could help me out with a couple of things. First off i have a B16A2 in a 90 DA with a S80 tranny, and some things are not matching up. For instance like the motor mounts and the cable to hydro conversion. I was just wondering if anyone has done this set up before and if so could someone please give me some pointers?
Ive never seen a B16A2 with an S80 tranny, as for the mounts, aftermarket mounts are very adjustable. ( If you mean that the stock mounts are not lining up). They also eliminate the front mount. Innovative are a good brand. like 75 track should do.
whats not matching up about your setup? just saying the motor mounts and cable to hydro conversion doesnt really help us out... what do you need pointers with is what i guess im getting at here
im using the innovative mounts and the transmission mount is not sitting right and the cable to hydro mount is not allowing me to put my fan back in place and the cable is not reaching. i know i should of been more in depth but i was in a hurry the other day sorry, im thinking about taking the transimission mount out and fitting it to where it will work but i was just making sure with anyone else who has maybe done this before that they ran into the same problem as me. i will up load some pics later of the cable to hydro kit so i can see if its the one to be using.
I am actually doing the same swap but with a gsr. I'm not having any problem with the cable and the conversion kit. But I did get the wrong tranny top mount(got one for b series hydro into Ef cable) I am going to pick up the right on from innovative to day. Post some pics for us to help. Btw, I am using the stock Da post mount, and the rear T bracket which I had to drill the holes out to fit the bolts for the S80 tranny.
Are you sure it wasn't converted to manual? Cuz the bracket on the frame where the motor mount bolts up to looks looks nothing like the 5 speed bracket. And it looks like the mount from the plate where it goes to the tranny needs to be longer to where it bolts to the chassis. The b series hydro to auto Da looks like the right one
well tomorrow or the next day im going to try and wiggle that **** in, its kinda hard sometimes to do this on my own but maybe i can get acouple of homeless people to help for some beer, lol. and yeah it does look like it is hittin the chassie, the axle is also sittin at an awkward angle too. ill try to line them all up again and take pics. thanks alot guys so far for your help and comments
Install the mount 1st. It will make it "slide" Right in...then again nothing slides right it with cars unless you are jesus christ. Haha But really, its a bitch if you dont bolt the mount down 1st
man i will try that, i havent been able to work on my car in a while, with school and work and just other stuff, but thanks for the input, i should be able to work on my car tomorrow
blaak-crx
Apr 23, 2008 09:02 PM
HOND PWR
Oct 22, 2004 07:49 PM
