Help design my new Audio setup!
Old Sep 3, 2009 | 06:11 AM
m R g S r's Avatar
Default Help design my new Audio setup!
So I have a 2010 Genesis coupe on order. Hopefully it gets here soon. Anyway it's the base model, and I was sure I was going to upgrade the stereo so I opted to not pay extra for the infinity stereo.
I have some leftover stuff from other cars, and would like to re-use some of it.
I want nice, clear crisp sound, that can be turned pretty high without distortion and without blowing my speakers!! I had a jl 12w7 and an amp i traded for a brand new clarion double din head unit, because I don't want to go the direction of super loud bass in this car.
So here is what I have:
-Clarion MAX385vd double din. I'm going to add the ipod interface wire, because that's what I listen to 99% of the time. I hate fm radio around here, and xm does not have that many channels that I like. I'm into house/electronic music.
-Infinity kappa 693.5i 6x9's
-MB quart PCE 213 5.25" components
-Hi fonics 440 watt 4ch amp
-Phoenix gold octane 8.0.4 4 ch amp
-zapco studio 300.x sub amp
So the MB quart speakers sounded good when I first got them, but when using them with my hifonics amp they eventually blew. One of the rubber surrounds ripped on my midwoofer, and the other makes a popping noise when it tries to reproduce bass.
I'm pretty set on getting rid of both 4 channel amps, because I'm positive I can do better. I was looking into a nice compact alpine pdx 4.100, but then came across the kenwood x4r for a little bit less $$.
Here's what I'm thinking, but still open to suggestions:
Use the clarion head unit (is the sound okay from this? I just traded it, didn't purchase it...)
use the infinity 6x9's for the rear speakers, keep the gain down (I know most say focus on front stage, but I like full car sound, and I have them, so I don't think it will hurt)
Use the tweeters and crossovers from the MB quart components.
I would like some 6.5" midwoofers for the doors to be used with the mentioned crossovers/tweets. What do you guys recommend?
What amp? Like I said, i would like something small and compact, but yet powerful and not dull sounding. either a pdx 4.100, 4.150, x4r etc??
And I still haven't decided on sub and sub amp. I always like jl stuff for subs and sub amps, but don't want to kill the budget i'm on. Either way, the sub and sub amp can be added later, i will wire for them to make it easy.
Maybe a single 12" in a small sealed box with the zapco amp?
Also, wires? Do I need 2 or 0/1 gauge? Or is 4 okay? What RCA's do you guys recommend?
And dynamat? I will most likely do the doors and some interior panels, but do not want to do the whole car, i think its pretty solid from the factory, its not a 97 civic like i'm used to
Old Sep 5, 2009 | 12:04 AM
twentyhurtz's Avatar
Default Re: Help design my new Audio setup!
ok i haven't seen the inside of a genesis, yes true most new cars have larger radio openings and full hu/ac controls setups, but you need to make sure you have room for a double din before you set your mind on that hu, you may end up needing to trade it, my quarts- keep those, even if you can't fit them in factory locations, they can always go in some qlogic kick panels , yea you need a little more of an audiophile amp, alpine is fairly decent stuff, zapco amp, i like... single 12", go back with jl.. its just daily listening, get a 12w6, they are so clean! also, if i was going for the nice clean crisp sound and had a new car,
personally i would go with 3 sets of components a 6ch amp or a pair of 4ch amps, and go with 1 or 2 subs,
oh and locate some old nice audiocontrol processors, nice and sweet
Old Sep 5, 2009 | 03:47 AM
m R g S r's Avatar
3 sets of components for a coupe? That's a little overkill. Most suggest only one set of good components for the fronts, you say 3? I don't think there is any need for that.
Thanks for the suggestion
I am thinking of running the CDT m6's as replacements for the MB quart blown speakers.
And an alpine pdx 4.150, that should be enough power for the front components.
But then I don't know if that's enough power for the sub coming from the tiny zapco. I guess I could just use it for now, then if I need more power just upgrade the sub amp after.
calvinnguy3n
Audio / Security / Video
16
Dec 14, 2006 05:20 PM
parasonic
Aug 13, 2003 11:34 PM
Revtoredline
Apr 27, 2003 01:10 AM
yellow blur
14
Dec 3, 2002 06:31 PM
deceit
May 13, 2002 06:12 PM
