How to Enter radio code to Acura Integra 1999
Old Sep 2, 2009 | 05:45 PM
tedydag's Avatar
New User
Icon3 How to Enter radio code to Acura Integra 1999
I have the serial number and code for my radio but I don't know how to enter it so can you please help me how to do that? The radio shows Err 3 I tried typing the code directly using the numbers but it is not working so please help me.
Thank you!!
Ted
Old Sep 2, 2009 | 06:33 PM
Autobotz8's Avatar
Default Re: How to Enter radio code to Acura Integra 1999
it should work after u've entered the correct #s, otherwise you got the wrong codes. It should be only 5 #s.
Old Sep 2, 2009 | 07:21 PM
8zero8's Avatar
u gotta keep punching in numbers till it resets... each number should spell out c-o-d-e on the face.. and it should beep when it resets. so keep punching in till nothings there. then put the code in.
Old Sep 3, 2009 | 06:35 AM
follie gatts's Avatar
Err 3 means you tried 3 times and didn't get it right. disconnect your battery for 10 minutes, hook it back up, and it will say COdE again. you get 3 more chances to type it in correctly.
Old Sep 3, 2009 | 07:52 AM
Circusraven's Avatar
^^ what he said is great information.
Old Sep 12, 2009 | 04:37 PM
krista22384's Avatar
New User
Does anyone know how to enter a 7 on the radio code for a 1998 integra?
Old Sep 13, 2009 | 03:02 PM
integra radio codes only use the digits 12345
Old Sep 13, 2009 | 05:44 PM
hushypushy's Avatar
^ they also use 6. My radio code is 63464, I have to enter it in all the time...
If your code has a 7 in it, it's not correct.
Old Sep 14, 2009 | 07:21 AM
kojack_0's Avatar
here you go:
https://radio-navicode.honda.com/
you enter the code incorrectly more than three times radio will lock up.
let the car ignition on and radio on for over 1 hour, this unlocks radio again and input code.
Old Sep 14, 2009 | 07:23 AM
mrdeadman's Avatar
They let me pick
How do you input a six?
And on that honda code website it states there are only 5 inputs... Have you actually tried your code with the 6?
Old Sep 14, 2009 | 06:23 PM
hushypushy's Avatar
Did you read the part where I stated my radio code and mentioned inputting it several times?
I have this tape deck, the one(s) on the left. Check out the buttons...
(stole this pic from HT marketplace)
Old Sep 14, 2009 | 11:01 PM
white_gsr's Avatar
My stock stereo is way different then those. Did they change depending on the year?
Here is my stock radio
Kojack thanks for that link i got my code nd it worked. Bump for good info
Old Sep 15, 2009 | 11:08 AM
hushypushy's Avatar
Well......you have a CD player man. The ones I posted are tape decks. Of course they will be different Some cars got tape decks with add on CD players...some got CD players with add on tape decks. My car happened to come with a tape deck and a trunk mounted CD changer from the dealership.
btw, the CD player on the right is not OEM.
Old Sep 15, 2009 | 11:16 AM
TYPE-R#945's Avatar
if you send me your serial number ill give you your code and and Ill tell you how to enter your code,your radio went into lock mode and you hae to disconnect the battery for few seconds....thats how we do it at work or we pull the radio back up fuse,but I think its better for you to disconnect the battery...
Old Sep 15, 2009 | 11:40 AM
white_gsr's Avatar
O Yea your right my bad!
Old Sep 16, 2009 | 10:50 PM
kojack_0's Avatar
serial numbers for oem radios and oem navis are located in the glove box itself. [a sticker]
or a card when you buy your car brand new.
Old Sep 19, 2009 | 07:39 PM
safedriver's Avatar
To answer the "how do you enter a 6", the radio can have 6 pre-set stations programed in to it.
Press the 6th pre-set button to enter the number 6.
Both of my Integras have a 6 in their code.
Old Feb 25, 2013 | 06:01 PM
a_lopez_6's Avatar
Icon6 Re: How to Enter radio code to Acura Integra 1999
SO i just bought a Acura Integra year '99 and was hoping you could get me the code to unlock the stereo (FA056333) serial # @TYPE-R#945
Old Dec 15, 2019 | 07:54 PM
Chris Heath's Avatar
Thank you!!
Ted
s13hero
Aug 6, 2011 12:55 PM
here4advise
Acura TL, RL & ZDX
20
Oct 10, 2009 03:11 PM
greyejcoupe
Oct 30, 2008 03:27 PM
mrsnj20
Sep 5, 2007 03:35 PM
micah128
Feb 20, 2007 11:25 AM
