How do i replace the front motor mount
Old Sep 2, 2009 | 04:20 PM
93califerio's Avatar
Default How do i replace the front motor mount
I have a ef hatch with sohc zc the engine shakes when i shift grears.
So i see the front motor mount move when i press on gas. I never changed out a motor mount so i dont even knoe where to start from i really would appreciate some help thanks
Old Sep 2, 2009 | 04:35 PM
Slo-mo's Avatar
Default Re: How do i replace the front motor mount
pretty sure it simple as supporting the motor then swapping mounts.but im sure i'll get flamed for that one
Old Sep 2, 2009 | 04:52 PM
So doi just unbolt the mount and take it out.
Old Sep 2, 2009 | 05:00 PM
beansandrice's Avatar
It is easy man. That is why no one is responding. Just unbolt it and it comes off.
Old Sep 2, 2009 | 05:19 PM
So i dont to put anything under the engine to suport the weight ?
Just unbolt it and take it off
Old Sep 2, 2009 | 05:27 PM
Mr. DeOro's Avatar
all you have to do is unbolt the old and put in the new.... all the other mounts will hold it in position.
Old Sep 2, 2009 | 08:02 PM
JOE BD-0's Avatar
x2
you might have to gently pry the motor a bit to get it out/in but it's easy and will work.
good luck.
85_305
Honda Civic (2001 - 2005)
19
Jul 28, 2009 02:14 PM
ShadyBAB
Dec 29, 2005 04:19 PM
P73 DA9
Jul 9, 2001 08:58 PM
