is there any companies that make the lsd for a sohc motor or should i just weld
i dont drive my street car much but to work and back and to the track
is it bad to weld it
will it brake with so much power
like me a 275hp weight 2250 lbs
so i run low low 12's with slicks andt 13.0 with street tires
are there any companys that make them ofr a sohc
if so
what and do you know how mcuh they run
thanx
if so
thanx
I know Quaife makes them for the SOHC's and I think Phantom grip makes a kit, but don't quote me on that one.
KAAZ makes an LSD for racing and street ... check out http://www.kaazusa.com
Tell Ray that Greg Samaroo sent you.
Greg
Greg
DO NOT WELD YOUR DIFF FOR THE STREET. It's even illegal at the drags but guys do it. Welded diff will not go around corners properly. Will break parts and ruin tires. If you want the best, go Quaife (which I sell, hint) but they are expensive.
Nate...dont do open Polls for people to add choices. People tend to get retarded and make dumb choices for you. Then the mods and admin get upset. It makes a big hassle.
Quaife makes good stuff.
[Modified by LSDelSol, 3:09 AM 8/29/2002]
**** 275 hp is that to the wheels? Whats your setup if you don't mind telling??
yeap hes right
but its 13psi daily
i have one of the best mechanics in san antonio( by my opinion)
but its 13psi daily
How about tuning you got your self a standalone I take it?? because your making a lot of power for the boost level.
Also the weight of your car does that include you? I would like to hit 13s in my car its got 196whp and weighs 2522 including driver.
[Modified by turbozxi, 5:21 AM 8/30/2002]
dem0nk1d
Nov 6, 2006 05:23 PM
Vtecme92
Jul 11, 2006 02:56 AM
