b16 swap this weekend....am I doing it right?
I am creating this post in order to make sure that I am getting this part of the installation right. If Im doing it wrong let me know. I am dropping a b16a obd0 into my 1991 honda civic hatch this weekend and I have an issuse that I was hoping someone can help me with
Besides adding wires for the second o2 sensor, the vetc and the nock sensor can I just plug my wiring from my pm5 cpu into the pwo cpu that came with the motor? If not does someone have a link to the pinouts for the pm5 and pw0 cpu.
Thanks
Fairburn
p.s most of the FAQ's on this issue are all dead links which is why I am asking this.
Thanks
Fairburn
PM5 is a dx harness (dpfi)
yes it will plug into obdo but you have to add addition wires like you stated.
also need to add mpfi wiring as well.
I dont think obdo's have knock sensors.
mine did not.
I had to add second o2 sensor, vtec wires and that was it.
I have a si so I already had the mpfi.
https://honda-tech.com/forums/hybrid-engine-swaps-18/faq-detailed-b-series-swap-into-5th-gen-civic-how-check-out-help-everyone-else-too-131949/
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/b16-2nd-o2-sensor-900501/
look at the top and there is afaq 2.0 you will find alot of the info.
mine did not.
the answer is yes, and heres a link that could help you out, as i used this guide with my 89si hatch i just did.
http://crxcommunity.com/viewtopic.php?f=15&t=173
this is the website I got my knock sensor info from
http://www.hondata.com/techecuid.html
thanks for all the helpful info
but the FAQ 2.0 is where I found a bunch of the dead links.
