vtec wont hit
Old Sep 2, 2009 | 11:44 AM
jdm-as-f@$k's Avatar
Default vtec wont hit
tried diffrent solinoids diffrent ecu has plenty of oil wiring was checked but still wont hit??
Old Sep 2, 2009 | 11:54 AM
HondaGuy951's Avatar
Default Re: vtec wont hit
motor?, cel's? got all o2 and knock sensors, tps, map and what not?! need lots more info!
Old Sep 2, 2009 | 12:11 PM
Scott4uf21's Avatar
How is your cluster working? vtec won't hit if speedometer or tach is not functioning properly.
Old Sep 2, 2009 | 01:19 PM
shoklid's Avatar
and how is that ?
Old Sep 2, 2009 | 01:20 PM
shoklid's Avatar
hahahahahahaha i like the pic of the joker to funny
Old Sep 2, 2009 | 01:46 PM
ls vtec.....it wud hit but i had it parked for like a week and when i tried to drive it again vtec wudnt cross over
Old Sep 2, 2009 | 01:52 PM
Bangher4$'s Avatar
oil level?
vtec shouldnt have a "hit"
hard hitting vtec's = FAIL!!!
Old Sep 2, 2009 | 01:56 PM
Jimster480's Avatar
alot of CEL's prevent VTEC from engaging. Do you have a CEL?
Old Sep 2, 2009 | 01:58 PM
yea actually have a cel ill have 2 ask my friend to check it out thanks
Old Sep 2, 2009 | 02:06 PM
Jimster480's Avatar
you just need to jump the service connector in the little green or grey rubber holder that is next to the ECU.
Old Sep 2, 2009 | 02:13 PM
shoklid's Avatar
just so u know use a paper clip in the 2 prong harness
Old Sep 2, 2009 | 03:15 PM
Rok_Stok's Avatar
My jumper is blue.
Old Sep 2, 2009 | 04:54 PM
Jimster480's Avatar
Originally Posted by Rok_Stok
My jumper is blue.
the rubber thing that holds it is blue? Or the connector is blue. because on EG's they are blue and on EK's they are grey. But the rubber holder is green (at least in my car).
Old Sep 2, 2009 | 05:05 PM
shoklid's Avatar
the rubber holder is called a harness fyi
shoklid's Avatar
either way it should b a 2 prong harness so u can stick a paper clip into it to complete the circuit and codes will appear on dash cel
Old Sep 2, 2009 | 05:35 PM
Linked's Avatar
not 100% correct
my ej1 (eg) 2 prong connector was green and wasnt even plugged into anything, was like that when i bought it.
i havent checked my ecu but i believe i have a d16z6 and p28ecu (havent checked engine code on my block, just have the vtec valve cover)
Old Sep 2, 2009 | 05:38 PM
Jimster480's Avatar
ok well i dont consider it a harness since its just a little rubber POS that does nothing. And why do you keep double posting btw?
Old Sep 2, 2009 | 06:28 PM
Vindicator9000's Avatar
318 Curves, 11 miles
WE HAVE OUR WINNER!!
99% sure that's why. Vtec doesn't work with a lot (but not all) CELs. I've found that it will still go with codes 1607, 1427, and whatever the VSS is, but almost anything actually related to running the engine will disable it.
It would be best if you could get the 4 digit code, as it gives a little more information than the service jumper codes. You'll need to borrow a scantool from an auto parts store for that though.
Old Sep 2, 2009 | 07:00 PM
Bangher4$'s Avatar
if you have a obd1 ecu then you do need to count the flashes via jumping the service connector.
If you have a obd2 ecu/car then you need the scan tool.
the VSS is the vehicle speed sensor, and you will not have vtec if its not working, unless you have a chipped obd1 ecu and the vtec speed check is disabled.
low oil psi will cause vtec to not engauge aswell, so much mis-information started in this thread.
Pull the codes and tell us what they are, untill then you dont know.
Old Sep 2, 2009 | 08:52 PM
hastingsr's Avatar
did you check your vtec fluid
Old Sep 2, 2009 | 09:19 PM
300whpej's Avatar
^i was thinking the same thing.
collinpoarh123
Apr 14, 2017 08:35 AM
tthoj
26
Feb 4, 2010 04:41 AM
vietblood87
Jul 14, 2007 09:58 PM
MOST
11
Feb 28, 2007 01:29 AM
oMek
Dec 12, 2003 10:07 AM
