vtec wont hit
Re: vtec wont hit
either way it should b a 2 prong harness so u can stick a paper clip into it to complete the circuit and codes will appear on dash cel
Re: vtec wont hit
my ej1 (eg) 2 prong connector was green and wasnt even plugged into anything, was like that when i bought it.
i havent checked my ecu but i believe i have a d16z6 and p28ecu (havent checked engine code on my block, just have the vtec valve cover)
318 Curves, 11 miles
Re: vtec wont hit
99% sure that's why. Vtec doesn't work with a lot (but not all) CELs. I've found that it will still go with codes 1607, 1427, and whatever the VSS is, but almost anything actually related to running the engine will disable it.
It would be best if you could get the 4 digit code, as it gives a little more information than the service jumper codes. You'll need to borrow a scantool from an auto parts store for that though.
Re: vtec wont hit
if you have a obd1 ecu then you do need to count the flashes via jumping the service connector.
If you have a obd2 ecu/car then you need the scan tool.
the VSS is the vehicle speed sensor, and you will not have vtec if its not working, unless you have a chipped obd1 ecu and the vtec speed check is disabled.
low oil psi will cause vtec to not engauge aswell, so much mis-information started in this thread.
Pull the codes and tell us what they are, untill then you dont know.
