b20 vtec itb setup
i been thinking about building a B20/vtec with itb's but i wanna throw in a big shot of nitrous is it possible to use a direct port nitrous system with the itb's? Has anyone done this before? Thanks for your help
coo so what compression ratio do you guys recommend to run on that set up?
right now i currently have an ls/vtec running itr spec forged pistons is that compression ratio good or what do you guys recommend?
question is are they standard b20 sleeves?
high compression + b20-sleeves + big shot requires spot on tuning or
i was piecing together my next season b20vtec but strayed away because of the unforgivability of the b20 sleeves and went 81mm instead.
for a street motor on pump gas and 50-150shot i'd say stick around 10.5-11.5:1 c/r
decent off spray power and enough power on spray to spin 3rd gear
well i was planning to sleeve the b20 i know about the sleeves on the b20, so i was definately gonna do that plus i was gonna run either 100 or c16 since its gonna be a track car
Bore c-c is about 90mm on B's, so they could fit.
I thought we did all the crazy huge ITBs though, who's making 72s????? that's absolutely insane for a B, 68s are too big for the biggest K's...
i just said i knew someone who did it. i never said i didn't think he was an idiot...
nah, he just slapped some big a$$ cams in there and expected it to last. it wasn't even tuned. but then again it would have just blown up on the dyno
dirtrdr22CRX
Aug 27, 2009 07:29 PM
