03 Odyssey Vapor Cannister. Where is it?
Have had a gas smell inside the cabin and after repeated trips to the dealer, and inspections of the fuel lines and AC, can't find the cause. Could this be the vapor cannister gone bad and if so, where is it?
RECALL NOTICE SUMMARY
This recall summary reflects information submitted by the vehicle manufacturer. While it is an accurate reflection of the information submitted, the NHTSA and/or the vehicle manufacturer may make changes at any time. No warranty, expressed or implied, is made as to its accuracy or completeness, nor is any responsibility assumed by Tecfacts Services, LLC. for loss, damages (direct or indirect). consequential or compensatory, including without limitation, lost profits, breaches or defaults caused by reliance on the information in this summary.
Copyright © Tecfacts Services, LLC 2004. All rights reserved. No portion of this document may be reproduced, copied,
transmitted, distributed or stored, by any means, in any form electrical or mechanical, including recording or by any
information storage or retrieval system without written permission.
AMERICAN HONDA MOTOR CO.
03V014000,
MFR
12/4/2002-1/24/2003
1/16/2003
2003 HONDA ODYSSEY
8857
ON CERTAIN MINI VANS, SOME FUEL TANKS HAVE SURFACE IMPERFECTIONS THAT COULD ALLOW FUEL TO LEAK FROM THE TANK.
FUEL LEAKAGE, IN THE PRESENCE OF AN IGNITION SOURCE, COULD RESULT IN A FIRE.
DEALERS WILL INSPECT THE FUEL TANK FOR SURFACE IMPERFECTIONS. IF ANY IMPERFECTIONS ARE FOUND, THE FUEL TANK WILL BE REPLACED. OWNER
NOTIFICATION BEGAN JANUARY 16, 2003. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT HONDA AT 1-800-999-1009.
Or check on this TSB: http://www.in.honda.com/Rjanisis/pubs/SB/A03-008.PDF
Do you have a CEL on or a code stored?
Common fuel leaks are the filler neck area or the top of fuel tank/fuel pump area.
03V014000,
MFR
12/4/2002-1/24/2003
1/16/2003
2003 HONDA ODYSSEY
8857
thanks for the recall notice, but it has been checked out with this recall number. The dealer has done a complete fuel line inspection as well as a smoke test. This is what makes me think that it is the vapor cannister.
The EVAP Canister is located driver's side engine compartment.
Other checks:
EVAP Bypass Solenoid Valve
EVAP 2-way Valve
Vacuum Test
Fuel Tank Vapour Control Valve
EVAP Canister
Vent shut-off O-ring
EVAP Canister Vent Shut-off Valve
No codes stored?
Other checks:
EVAP 2-way Valve
Vacuum Test
EVAP Canister
No codes stored?
I thought the canister and associated parts were under the vehicle. Near the fuel tank.
from looking at that pic it does appear that the cannister is in the engine compartment, but it is, in fact under the vehicle. as a HONDA TECHNICIAN I should know since I'm under them all the time. not trying to discredit you but that picture is misleading. in fact that pic would lead you to believe that the gas tank in on the passenger side of the vehicle, also, which it is not. the EVAP cannister is just forward of the fuel tank almost directly under the drivers footwell.
No worries. Actually, you are right, now that I see how the diagram is laid out. It is not in the engine compartment but as you say in front of the fuel tank under the van. Thanks for the clarification as I am not a Honda Tech and learn so much from you guys. Does this mean I have to leave this fine forum now?
oh and yeah, change that avatar... this IS "HONDA-TECH"... j/k dude, I actually like and respect the STI too...
silverb18
38
May 9, 2005 07:42 PM
powerfinger
May 18, 2004 05:02 AM
