crank angle sensor???
Old Aug 26, 2002 | 07:51 PM
prjctCIVIC's Avatar
Default crank angle sensor???
is there a crank angle sensor in a 90 crx si???
Old Aug 26, 2002 | 07:54 PM
Francois's Avatar
Default Re: crank angle sensor??? (prjctCIVIC)
There's a crank pickup coil in your distributor.
Old Aug 26, 2002 | 07:58 PM
USDM 4G VTEC's Avatar
yes
they all have a crank angle sensor on their distribuitor..... the crank angle sensor its made out of two individual sensors.... the CYL sensor and the TDC sensor. The CYl sensor detects the position of the #1 cil as the base of the sequential fuel injection system. The TDC sensor determines the inyector timing for each cylinder, as well as sendint the ECU the engine speed signal.....
Old Aug 26, 2002 | 08:06 PM
prjctCIVIC's Avatar
Default Re: crank angle sensor??? (JDM EF9)
im plannig on doing a 96 SOHC VTEC swap and was wondering abou thtat sensor...but since im using the crx intake manifold, ecu, distributor, and wiring i wouldnt have to worry about the crank angle sensor on the block because its in the distributor already, right???
Old Aug 26, 2002 | 08:31 PM
Francois's Avatar
Right!
Old Aug 26, 2002 | 08:34 PM
prjctCIVIC's Avatar
Default Re: crank angle sensor??? (Francois)
thanks thats all i needed...thanks for the replys
SwappedLSHatch
Apr 13, 2006 01:33 PM
Nvious R
Oct 28, 2003 06:27 PM
The Jamaican
Apr 14, 2003 07:54 PM
