GSR swaybar/endlink ?
SOOO
I got a rear swaybar for my car. I think its a GSR. its 14 mm
anyway, I got my endlinks in and the bushings in on the end of the swaybar along with the collars that go inside the bushings.
Well the endlink bolts that come with the Blox adjustable endlinks are too big for those collars that push into the end of the swaybar within the bushing. They would fit great without the collars in there. Is it ok without that collar? because the bolt has a smooth spot that fits perfectly where the collar would be.
What do you guys think?
these bolts to the right give a good example of the smooth part. check it.
Part 8 + 11 here are what fits but the bolt wont fit through
maybe I'm just installing the endlinks on wrong and the angled washers go into where the bushings are on the end of the sway bar?
That seemed to work the best and fit very well but then the endlinks can't pivot on the threaded half of the bolt.
I'm lost :/ I have no idea how it would work unless I can get different collars for those end bushings...
jdm_j03
Aug 22, 2007 01:38 PM
byronl
Jul 18, 2006 05:54 PM
