power loss with 4-2-1 headers?
Old Sep 1, 2009 | 06:21 PM
jamaicantourist's Avatar
Default power loss with 4-2-1 headers?
going to temporarily change my 99 spec 4-1 headers with some 96 spec 4-2-1 headers , what loss will i see? surely not anything major?
Old Sep 1, 2009 | 06:32 PM
jeff652's Avatar
Default Re: power loss with 4-2-1 headers?
surely.
Old Sep 1, 2009 | 06:41 PM
really? forgot to mention im talking jdm type rs not sure about yall
i think these are what ill use;
im thinking more bottom end power? lol like i need it i have a b20 bottom and a few mods, tyres spinning all over the damn place, lol
id like a dyno figure still... nothing really, to ask... lol
Old Sep 1, 2009 | 07:03 PM
Dark_Teg's Avatar
I have ran both and couldnt really tell the difference. The only reason I went to the 4 to 1 header was the 8.5 lbs weight savings.
Old Sep 1, 2009 | 07:06 PM
thanks alot makes me feel bet... HOLD ON! b8.5lbs lighter?
Old Sep 1, 2009 | 07:27 PM
Dark_Teg's Avatar
My 96 spec JDM ITR swap came with the 4-2-1 header. Due to the fact that it is heavy and ugly I went to the JDM 4-1 ITR header. I weighed them both for the hell of it and the 4-1 is 8.5 lbs lighter. I honestly couldnt tell a difference in performance.
Old Sep 1, 2009 | 10:08 PM
racebum's Avatar
as far as i know, there isn't a performance difference. the 98+ motor has a slightly better torque curve. i just have no idea if that came from an ecu map tweak or the header. the 96-97 header is like the bargain header of all times. you can get one for $150 all day and they actually perform
Old Sep 2, 2009 | 03:28 AM
SlapSmak's Avatar
the reason the 98+ motor has a little better performance was the intake cam has better lift and duration. exhaust cam was the same, that of course had a slightly different map on the ECU. the 98+ JDM motors also had the 4-1 Header which yeilded about 3-5 HP, maybe a little more with Tuning on a Hondata or other tunable ECU setup.
A built B20 setup would benifit greatly from a larger primary header, a little JDM 4-2-1 or even a 4-1 would give OK gains, but a nice B20 header would yeld some great numbers if it was tuned.
Old Sep 2, 2009 | 12:03 PM
thundernoodle's Avatar
I cant see 3 degrees helping much if at all.
Old Sep 2, 2009 | 12:35 PM
SlapSmak's Avatar
I would almost agree with you, but just doing a valve adjustment to the tightest spec gives you some noticable gains which will show on a dyno, so even 3 degrees yields a small gain. Here is an old post with all the Cams out there for B series, the duration spread starts at about 3 degrees between levels and goes up from there. lift does not substantially increase as the threat of slapping a valve to a piston is already an issue.
https://honda-tech.com/forums/acura-integra-type-r-8/98-itr-ctr-intake-cam-%3D-zooommm-1388379/
OP, to your original question, I still think you would see a power loss with a 4-2-1 from a 4-1 as you are running a b20 bottom end. Big tube headers give some good gains on a B20 hybrid motor, and choking it down with a 4-2-1 will decrease performance IMO.
Old Sep 2, 2009 | 12:54 PM
It just seems like a trivial difference between cams. However I guess they designed it like that for a reason, right?
Old Sep 2, 2009 | 01:48 PM
SlapSmak's Avatar
Yep, consider that although 3 degrees seems small, it allows 1.4 % more fuel/air into the chamber on any given stroke, so that would give you a slight increase in available charge, giving you about the same change in HP, maybe 2-3 between the 96 spec to the 98 spec.
If I was going the Cam route, I would go Jun stage 2-ish if I could find em.
Old Sep 3, 2009 | 07:54 AM
Tyrant_007's Avatar
So I take it you decided not to sell your caR?
Old Sep 3, 2009 | 07:36 PM
an2ny888's Avatar
the jdm 4-2-1 actually has bigger primaries (id) then the jdm 4-1
Old Sep 4, 2009 | 06:35 PM
well i decided to keep my headers, and im not sure about selling the car, its hard to replace, you guys should know how that feels... lol
Old Sep 4, 2009 | 07:45 PM
racebum's Avatar
that 3deg is only @1mm, total duration i thought was unchanged. also, for the jdm motors, more than a few places mention the cams being the same 96-01, i know the us cars got the ctr cam in late production but i have never been able to confirm it on jdm. personally, i can't see how such a tiny cam difference could bring on much of anything. even going to skunk1's which are larger than either rarely gets anyone more than 3-5hp over plain itrs
the ecu or header i could see easily creating the better torque curve which is all the 98+ has. there is no hp difference
MD94GSR
Feb 24, 2005 09:07 AM
TeachHist2005
42
Nov 11, 2003 05:38 AM
ofl
Jun 26, 2003 12:57 PM
Rratedcivichatch
Dec 26, 2002 10:43 AM
