brakes dragging after change
Old Sep 1, 2009 | 02:14 PM
coot_er's Avatar
Default brakes dragging after change
I just replace the front rotors and pads on my 89 crx si. the pads i used were PBR ULT (formerly axxis ultimates) and i resurfaced some rotors off of a 90 dx sedan. the pads did look a big meaty and i did have to kind of smack the caliper down over the rotor. Do i just drive and let them wear or what do i do?
Old Sep 1, 2009 | 07:52 PM
coot_er's Avatar
Default Re: brakes dragging after change
Ok well i bought a new rotor to see if that was the problem. Of course the place i went to didn't have 89 in there system, but they had 88 and 90 and they were the same part number so i figured 89 had to be the same as well. i put the new rotor on. the caliper, with the pads loaded, slid on alot easier. i bolted the caliper in place and spun the hub and everything was cool. i put my wheel on and hand tighten the lugs and it freezes up! what the heck is going on?
Old Sep 1, 2009 | 09:19 PM
skidmarkroyalty's Avatar
did you reset your caliper pistons before you put the new pads on?
Old Sep 1, 2009 | 09:46 PM
77amc's Avatar
Sounds like a bad caliper.. When was the last time you flushed the fluid/cleaned the res?
E
Old Sep 2, 2009 | 07:29 AM
Tyson's Avatar
dx sedan rotors are not the same as crx or hatch rotors. they are thicker, and slightly smaller diameter, hardly noticable. but it is definitely noticably thicker. thats your problem.
Old Sep 2, 2009 | 07:45 AM
Mr. DeOro's Avatar
nice!!
Old Sep 2, 2009 | 01:32 PM
coot_er's Avatar
Yes, but i am going to double check it.
Old Sep 2, 2009 | 01:34 PM
coot_er's Avatar
E
The caliper was fine the last time i drove it. i really have not even touched the brake pedal and it is dragging. I flushed my fluid about 4 months ago.
Old Sep 2, 2009 | 04:44 PM
coot_er's Avatar
Found the problem. The idiot sent me the wrong pads!
Old Sep 2, 2009 | 05:19 PM
Mr. DeOro's Avatar
that'll do it
ryanangelo212
Jun 3, 2013 11:42 PM
CO671
35
May 26, 2012 08:21 AM
janz3n
19
Apr 17, 2007 01:25 PM
Los.
Jan 14, 2005 05:19 PM
Vampyre
Nov 1, 2002 09:46 PM
