View Poll Results: Do you think my car is worth the asking price?
yes, it has potential..
40.00%
No, this is a mess..
60.00%
Multiple Choice Poll. Voters: 5. You may not vote on this poll
TN 94 Integra gsr/typeR engine,trans,5lug,mugen 5way, 6point roll cage
Old Sep 1, 2009 | 02:10 PM
purehonda12's Avatar
Icon7 94 Integra gsr/typeR engine,trans,5lug,mugen 5way, 6point roll cage
At one time this car was my pride and joy! After buying a house, a dog,
and a boat I seem to always have something I would rather do than be in
the garage working on my car. I have had the car for almost 5 years now
and have sunk all kinds of money into it. When I first bought the car it
was completely stock with high miles and I spent 3000$. I have had
several Integras before including a Type R but I wrecked the R due to my
immaturity. After that I decided to build a GSR using all R parts to
make a high performance, low insurance cost car. I live in a fairly
small town in TN and when I heard of an acquaintance wrecking his R I
gave him a call to see if he wanted to sell the wreck. The donor car was
a 98 championship white Type R with 60k miles that I purchased for
4500$. I should have taken the motor transmission and suspension right
off the R and put it on my GSR but I had to go bigger. When I started
installing the suspension parts onto my GSR I realized that some of the
bushings were in bad shape. I ordered a complete polyurethane bushing
kit from Energy Suspension and replaced the troublesome bushings. I also
realized that the struts that were on the salvage Type R were in bad
shape. They had some cheap-o lowering springs on them and were
completely worn out. I started looking around for some better stuff and
came across a real find; a full set if Mugen 5 way adjustable springs
and struts. I paid 750$ for the slightly used suspension parts on eBay
but considering they were around 1500$ new that was a good price. After
installing all the parts, the car handled great and it was time to put a
roll cage in it. I called up a company that makes pre-bent chrome-molly
cages for around $600. To install the cage, I had to cut and bevel the
tubing and then weld in all together inside the car. I weld piping for a
local chemical company so I did all the TIG welding in my garage. The
cage was intended to be an 8-point unit but after realizing that I would
have to cut the dash up to install the front two bars and the halo bar I
decided to just go with a 6-point. I have the tree other pieces in the
rafters of my garage and they will go with the car in case you would
like to install them. I took the transmission to a buddy in the business
and had him go threw it looking for anything that could be a problem.
The transmission was perfect inside and $60 later I had my transmission
back with a clean bill of health. I then took the motor to a local
machine shop that does lots of circle track cars and had them bore the
motor over .030 to match my Wiseco 9.5:1 compression pistons. They also
polished the crank and installed ARP head studs and main studs. The head
got a three-angle valve job and valve guide seals; a quick pressure test
$500 and it was back in my hands ready for assembly. I then brought my
entire collection of parts home and placed them in my garage where they
have sat covered in bed sheets with a light coat of WD-40. All the bolts
from the engine were labeled in zip lock bags and all the other bolts
were put into a pan that has sat underneath the car undisturbed. When I
pulled the GSR motor and transmission, I sold them to further fund my
project and purchased two JIC Magic fully adjustable racing seats and a
pair of 4-point harnesses. I used the sliders off of the factory GSR
seats and modified them to fit the JIC seats. I did this because when I
put the seats in using the JIC brackets it seemed as though I was
sitting way to high. When I was doing all of these modifications I
wanted to ensure that I didn’t just make a fast car I wanted it to be
really nice too. So, I re-installed the carpet cutting it where
necessary for the cage and made it cover where the back seat once was. I
bought the salvage 98 Type R with intentions of turbo charging the engine
and converting it to OBD1. This is done by using all the wires, sensors
and ECU out of the GSR. I have all of the sensors off and external
components from the GSR like starter, alternator and distributor. I also
have all the sensors and accessories off of the Type R to ensure an easy
build. After going through some tough times as a new home owner I have
sold some of the turbo parts such as the AEM EMS, turbo manifold, blow
off valve, waste gate, intercooler, piping and turbocharger. I still
have a Walbarow 255 fuel pump un-opened, and RC engineering 780cc
injectors also un-opened. The only damage to the car is small dents and
dings and the rust in the quarter panel’s shown in the pictures. I have
used older interior pictures of the car because even with a flash the
pictures didn’t look very good taken in my garage. I will be glad to
take more pictures of anything you want a better look at and email them
to you or answer any questions that I can. Please email me at
purehonda2000@hotmail.com
So, my total investment to-date is about $12,375.00 this is only the parts that are included. That's what you're
bidding on.
Here is a list of everything in the pictures that is included with the auction.. Basically if it says Honda/Acura on the part it’s included.
· 98 Integra Type R Intake Manifold w/ all sensors and injectors
· 98 Integra Type R Head (fresh 3 angle valve job, and valve guide seals)
· 98 Integra Type R cams
· 98 Integra Type R alternator
· 98 Integra Type R starter
· 98 Integra Type R block bored .030 over to match the pistons and rings
· 98 Integra Type R main caps
· 98 Integra Type R crankshaft
· 98 Integra Type R LSD Transmission
· 98 Integra Type R Front and Rear sway bars installed
· 98 Integra Type R distributor and plug wires
· 98 Integra Type R axils
· 98 Integra Type R brakes, control arms and brake lines installed
· 98 Integra Type R **** **** installed
· 98 Integra Type R wheels Gunmetal installed
· 98 Integra Type R All other sensors off the block
Here is a list of all the 94 GSR parts that are included:
· 94 GSR integra body w/ a clean title. The car also has a weld in 6-point cage
· 94 GSR integra dash, gauges, carpet, door panels, headlights HID Kit installed, Tail lights, everything under the hood is there and works A/C included.
· 94 GSR integra wiring harness, all sensors off block and head
· 94 GSR integra virgin p72 ecu
· 94 GSR integra distributor
· 94 GSR integra altinator
· 94 GSR integra starter
· 94 GSR integra motor mounts with Energy suspension race kit installed
· 94 GSR integra injectors
· 94 GSR integra shift linkage
· 94 GSR integra axils
Here is a list of all the performance parts that are included:
· New! Fidanza 7.5 lb flywheel
· New! RC engineering 780cc injectors
· New! Eagle H beam rods with upgraded bolts
· New! wiseco 9.5:1 pistons to match the block .030+
· Energy suspension trailing arm bushings installed
· MUGEN 5 way adjustable struts and springs combo installed ($1500 new)
· 2 JIC Magic suede seats fully adjustable with sliders
· 4 point harnesses on passenger and driver side
· Stainless Steal full exhaust, it’s a greddy knock off looks just like it some ebay special.. Sounds good though, it’s not really loud.
What you will need to buy to put the car back together:
· Clutch
· Exhaust manifold
· Timing belt
· Gasket kit from Honda
· Rod and main bearings
And, of course, some tender, loving care! But what you'll have when
you're done is an awesome Type R that insures as a regular Integra GSR.
I would like to get 5k$ out of everything..
Thanks for looking,
Joe Randall
Old Sep 1, 2009 | 02:35 PM
stevn's Avatar
Default Re: 94 Integra gsr/typeR engine,trans,5lug,mugen 5way, 6point roll cage
Nice project for someone who has a little time...
Old Sep 1, 2009 | 03:25 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Bump for viewing.
Old Sep 1, 2009 | 05:00 PM
caseyliffick's Avatar
No foolin'
Old Sep 3, 2009 | 07:52 AM
Icon5 Re: 94 Integra gsr/typeR engine,trans,5lug,mugen 5way, 6point roll cage
bump also will part out!
Old Sep 3, 2009 | 05:50 PM
hai_tech's Avatar
bump
Old Sep 3, 2009 | 07:35 PM
Jmsklmn's Avatar
Too bad your not is CA! I would love to pick this up! Goodluck, great deal!
Old Sep 3, 2009 | 08:45 PM
srt4mike's Avatar
Old Sep 3, 2009 | 11:09 PM
SkidmarkEH2's Avatar
ttt
Old Sep 16, 2009 | 01:28 PM
would anyone be interested in trading a truck or SUV for this integra project? I need a good truck..
99b18c
Dec 7, 2006 03:50 PM
supersonicblue
Mar 20, 2005 07:58 PM
RuskeR
Feb 5, 2005 05:22 PM
distuRbed
May 1, 2002 02:04 PM
