b18b1 into '89 Crx si(searched but need more help)
i just purchased an '89 Crx Si i've done swaps and rebuilds and all that before, i'm not bad with wiring...but i'm not exactly understanding this whole deal.
i've got a '94 b18b1 bottom end (w/ctr pistons)
'92 Ls head(stage 1 crower cams not installed yet)
stock Pr4 ecu (until i get it tuned)
from what i understand the Pm6 ecu is obd0 and the Pr4 ecu is obd0 also but why is it the Pr4 won't directly plug in? and what exact jumper harness am i needing?
i do have the engine harness from my '92 Da and the harness from the '89 Crx what modifications need to be done?
note* I HAVE searched but don't completely understand so please no bashing on me, just fill me in on info/direct me to the right spot, or dont post at all.
-Terrance
'89 CRX cabin ecu plugs
'89 CRX ecu (Pm6)
'92 Integra cabin ecu plugs
'92 integra Ecu (pr4)
sorry for the big picutes, there just quick cell phone pics.
-Terrance
'89 CRX ecu (Pm6)
-Terrance
-Terrance
stay with the pm6 and just get a base map
oh ok, i thought the obd1 ecu was p75....
i'm wanting to keep the pr4 because i'm not going to be getting a tune until my motor is broken in.
so until the motor is broken in, the crower cams won't be installed nor will i be getting a tune.
ecu should plug right in unless you have a obd1 pr4 ecu. mines plugs right in. obd 0 should have 3 plugs. obd 1 only have 2 plugs. check your ecu and plugs.
and in the mean time i can save for my tune as well
this isn't rocket science. you have an obd1 pr4 instead of an obd0 unit. from 94-95 the ecu was an obd1 p75. it remained p75 from 96+ and it was obd2 for those years.
ninja edit: obd0 ecu's do have 3 plugs, but 2 seperate colored areas on the ecu.
then i guess my cabin harness on my '89 Crx si is obd1 because both the harness and ecu have 3 seperate plugs
that's my bad. i meant to say that on the ecu jumper there would be 2 seperate plugs for the obd0 cabin harness to plug in, but on the harness itself there will be 3 seperate plugs (as seen in your picture).
the problem is you have an obd1 ecu there, and your stock harness will not plug into it without the proper jumper harness. so either get that harness or get an obd0 pr4.
wouldn't an obd0 to obd1 jumper harness be straight...considering obd1 ecu's have more of an advantage for tuning...?
sweet, so then i'll just get an obd0 to obd1 jumper harness and go from there...
http://rywire.com/store/obd0-obd1-co...3bbed215083122
would just like to make sure its the right product...^^^^^
