88 crx hf ls swap
Old Sep 1, 2009 | 12:44 PM
enigma2446's Avatar
Default 88 crx hf ls swap
ok im having trouble finding out what all i need to make this swap happen....all i know for sure is to get the rywire jump harness.....what else do i need?....and someone said that i need 88-91 dx or si knuckles for the ls axles...please help i need every bit of info to make this swap flawless
Old Sep 1, 2009 | 01:06 PM
enigma2446's Avatar
Default Re: 88 crx hf ls swap
also im takin the ls out of a 92 DA...will the knuckles off the da fit on my rex also will everything just line right up like linkege and mounts exc.???????please help
Old Sep 1, 2009 | 03:10 PM
black0hatch's Avatar
you dont need a jumper harness from rywire since its out of a 92 you just keep it obd0. yes you will also need dx or si knuckles because the hf's have a smaller axle. you can put da knuckles on but last time i tied it the front end couldnt be alligned right. you will also need after market mounts and linkage or cut the da linkage shorter. and youll need to beat on dent on the drivers frame rail for the alternator to clear. just search youll find a ton of info.
Old Sep 1, 2009 | 03:21 PM
enigma2446's Avatar
the 92 is a gsr witch is obd1
Old Sep 1, 2009 | 03:46 PM
djstevehawken's Avatar
black0hatch is correct, don't use DA knuckles it will throw everything off. I did a 95 LS swap in my 91 STD. Here's what I bought:
91 civic Si Knuckles
90-93 Integra Axles
90-93 Integra Radiator
90-93 Integra Throttle Cable
90-93 Integra Clutch Cable
Hasport B-Series Motor Mounts (Cable Tranny)
Hasport B-series Shift linkage
Also, someone please correct me if i'm wrong but the 88 CRX HF is dual point fuel injection? a MPFI (Multi-point) conversion would be needed.
Good luck!
Old Sep 1, 2009 | 05:35 PM
enigma2446's Avatar
where can i get the mpfi at or is it aftermarket???
Old Sep 1, 2009 | 05:37 PM
no hf is multi point but i think you need to change a couple dizzy plug wires not sure on that. and your title says ls swap but now its a old school gsr??
Old Sep 1, 2009 | 05:41 PM
enigma2446's Avatar
well its a 92 gsr that had the b17 in it well the guy before me blew it up so he droped a ls in it and thats where im at
Old Sep 1, 2009 | 06:34 PM
well if its allready obd1 and complete its gona be cheaper to just buy the jumper. but you can run it obd0.
Old Sep 1, 2009 | 06:51 PM
enigma2446's Avatar
how dou run it obd0 without a jumper harness?
Old Sep 1, 2009 | 07:04 PM
Twisted Image's Avatar
buy an obd0 ls ecu like a PR4. You will still need Swap mounts and a shift linkage. If you dont have access to a welder save the time and hassle and order a dependable shifter like a hasport swap shift linkage
PR4 ecus can be had less then $50
Swap mounts $200-$500
Linkage $100-$150
Spindles can be found anywhere. The best to use would be DX or SI CRX or Civic ones
Old Sep 1, 2009 | 07:12 PM
D16SiHatch's Avatar
yea its up to you whether you want to go obd0 or obd1. i suppose go whichever route would be the cheapest. it will run just fine either way.
Old Sep 8, 2009 | 03:47 PM
enigma2446's Avatar
ok im confused if i do keep it obd0 and get the pr4 ecu then how does the rest of the wiring line up like the distributor and what not please someone help i want it cheap and easy as possible
Old Sep 8, 2009 | 04:25 PM
jdmef9mang's Avatar
because its mpfi it should be plug and play just need the ecu as stated above, the axles and brakes( and mounts & shift linkage)
Old Sep 8, 2009 | 05:01 PM
enigma2446's Avatar
ok but what about the dist. its grey plug.aka obd1 how does that work remember this is a 92 obd1 ls...and about the brakes do i need the caliper and rotors??
Old Sep 8, 2009 | 05:04 PM
enigma2446's Avatar
what if i get an obd0 dist????????............so all i need is the pr4 ecu, mounts, linkige, knuckles and brakes right
Old Sep 8, 2009 | 10:13 PM
sh!ft's Avatar
Who the fack changed my title?!
and anything else like ball joints, if there out, as well as a clutch setup etc for swaping the motor over
Old Sep 9, 2009 | 04:13 PM
enigma2446's Avatar
ok so all i need is the pr4 ecu, obd0 dist., civic or si knucles, linkige, and mounts?????....anything im forgetting??? PLEASE HELP!!!!
Old Sep 9, 2009 | 04:20 PM
enigma2446's Avatar
i also have a question about the mounts can i or can i not use the motor mounts off the DA for the swap i have both the DA and the rex in mygorage....just wondering if i can use anything off the DA for my rex...anything at all would help ....and when i say anything i mean bumper to bumper the whole car lol sorry!!!!!!!
Old Sep 10, 2009 | 10:09 AM
enigma2446's Avatar
Old Sep 10, 2009 | 10:28 AM
D16SiHatch's Avatar
you cannot use the da mounts.
Old Sep 10, 2009 | 10:46 AM
enigma2446's Avatar
ok do they have to be aftermarket or can i use some off of another car!!!????
Old Sep 10, 2009 | 11:08 AM
D16SiHatch's Avatar
must be aftermarket. no other vehicles stock mounts will allow you to run a b-series in an 88-91 chassis.
Old Sep 10, 2009 | 11:15 AM
akshn1's Avatar
92-93 da is obd1
Old Sep 10, 2009 | 11:26 AM
enigma2446's Avatar
what brand would be the cheapest to getcuz hassprt is to high
