How to identify the difference between KAAZ & Quaife lsd on YS1 TRANNY *HELP*
I know KAAZ is clutch, quaife is helical... but I recently bought a YS1 tranny w/ aftermarket LSD installed. The tranny is see through, and there is no diff pin going through. I know it is not stock because it has those eyes holes, it is not straight through.
I can't tell if it is KAAZ or Quaife... which is important because if it is a clutch type tranny I want to make sure to use the Kaaz fluid instead of OEM honda.
If anyone knows how to tell the difference between LSD's once they have been installed the tranny, please let me know!!!!
Currently the tranny is just sitting on the floor
for the Kaaz clutches IF you have a Kaaz, if it is a Quaife, it won't hurt anything.
I put 50K street/race miles on mine, when Kaaz was surprised.
Thanks for the tip, glad you have experience with it.
I will pick up a tube of posi additive and a some syncromesh
It's been a while since I've used syncromesh - I should get the "friction modified" syncromesh right?
http://paceperformance.com/index.asp...D&ProdID=29478
http://paceperformance.com/index.asp...D&ProdID=41510
So is this the stuff I need? Thx for your help, just want to make sure I am getting the right stuff.
Autozone worked out perfect, found the syncromesh for 6.99.
So I cracked the case this weekend, took pictures... I don't think it is Quaife or KAAZ.
I know it is a standard helical LSD, NOT clutch-type now. But I have NO clue what type of final drive that is, or what type of LSD.
Any ideas?
Any ideas?
OBX is what I'd guess.
To tell if you have a clutch type or helical (with trans together), you can put the car in neutral and lift one front tire. Try to turn the tire. A helical will allow you to turn the tire as long as the trans is in neutral. A Kaaz or other clutch type will either not turn or give a good amount of resistance.
irev210
Aug 28, 2009 02:48 PM
acura, check, difference, differences, honda, integra, kaaz, lsd, opening, prelude, quaife, rsx, tranny, transmission, ys1
