anti theft 95 civic ej1
Old Sep 1, 2009 | 11:54 AM
lalocivic's Avatar
Default anti theft 95 civic ej1
well i have a ej1 just finished my project took a year! it got broken into in front of my house about a month and half ago took about 700 dollars worth of my stuff well i have a viper alarm regular no pager at the time it got stolen it had the same alarm well what they did is they pulled the latch from the front and broke it and disconnected the alarm now its easy to open they tried again on night about 3 weeks ago as alarm rang at about 5am and i ran out and tried to chase them down but got away since im scared to get jacked!i need help what u guys suggest for anti theft for my car kill switch new alarm with pager ect let me know guys what the safest way to go???
Old Sep 1, 2009 | 01:17 PM
Gumby99si's Avatar
Default Re: anti theft 95 civic ej1
put a switch for ur fuel pump and put a regular master lock on ur steering linkage under the dash
Old Sep 1, 2009 | 02:00 PM
jyacoba2009's Avatar
is it still running? if it is.. pull the fuel pump fuse in the fuse panel
or.. isnt there those hood pins with the locks on them?
Old Sep 1, 2009 | 02:30 PM
froshtyv's Avatar
Fuel pump is too common for a kill switch,
All a thief has to do is bring a 12v dc supply with them and tap onto the pump,
You can put one any where on the car really, id go with breaking a negative wire for one the cars needed parts.
Old Sep 3, 2009 | 10:31 PM
peter96ek's Avatar
take out ecu fuse
Old Sep 3, 2009 | 10:48 PM
Grevved's Avatar
I think you can get like a red kill switch key thingy from Schucks or some auto part store. Pretty much just a quick disconnect from pos/neg for battery. Buddy of mine put one in his car. Just hid it under dash.
Have motion-senor lights in your driveway?
Security camera's are good investment, neighbor runs his off of his computer from his front window.
GL
Old Sep 4, 2009 | 12:07 AM
MHDesigns's Avatar
Like a fuel pump?
Old Sep 4, 2009 | 06:06 AM
RyanA's Avatar
Sounds like you need to add a hood switch. If you want extra security, add 2 of them. If you want to buy a little bit of time, you could put a bicycle lock on your hood latch ring on the hood itself and have it lock to the radiator support. I'm talking about a cable or chain type bicycle lock. By doing this, they will try to open the hood but be limited how far it will open. It will be hard to get to the battery to disconnect and the alarm will be going off since you have hood pin switch(es).
Kill switches that are pretty effective are:
1. Fuel cut but wire it in UNDER the access cover. That way, if a thief tries to wire the pump, it still won't work.
2. Ignition cut. Interrupt the distributor power feed anywhere en-route to the distributor.
3. Main relay cut.
4. ECU power cut (just interrupt switched ignition.
5. Dummy ECU (it takes a little time but put an ECU in the car that only has the connectors. Cut the board off of a bad ECU.
6. Make your ECU where it has to be YOUR ECU to start the car. Move a power input to an unused pin on the ECU. Cut the normal power feed pin and solder a wire between your pin and the correct one. By moving the power, if they try another ECU, it will not work.
7. Battery backup on your alarm. even if they cut your battery cable, the backup battery will sense this and automatically set off your siren.
BJIntegra
Oct 16, 2009 04:25 PM
BoboyRS
Audio / Security / Video
17
Jan 15, 2009 08:58 AM
dingusjt
May 18, 2006 09:38 AM
cxSHOE
Aug 20, 2005 12:46 PM
return_2020
Aug 16, 2005 08:22 AM
