95 dc pass window not working??
Old Sep 1, 2009 | 09:50 AM
dc4teg95's Avatar
Default 95 dc pass window not working??
OK so my pass side window just stopped working. Works fine with the driver switch so i tried replacing the pass side switch. No luck so changed driver side as well still no luck. double checked to make sure window lock was off and it was. checked all fuses. nothing. Can any one help me figure this out?
Old Sep 1, 2009 | 11:28 AM
fcm's Avatar
fcm
Old Fart
Default Re: 95 dc pass window not working??
Check for power at the pass. door window switch, the blue/black lead at switch plug should be 12V+ when ign. switch is on.
It will not be a fuse problem, [fuse 8 -20A in under dash fuse box] as the window works from drivers door, [same fuse], my guess is a connection problem at the door harness plug with the blue/black power lead for the switch.
It is a good bet the pass. door switch is good as the power and ground from the drivers side pass. window switch must go "through" the pass. side window switch before it gets to the pass. side window motor, so pull the pass. door window switch and test for power on the blue/black. 94
Old Sep 1, 2009 | 12:26 PM
dc4teg95's Avatar
ok thanks i will try once i get off work
speedfreak44
Aug 25, 2010 01:33 PM
hondapwr
Jul 17, 2009 05:30 PM
BauleyCivic
May 1, 2005 04:42 PM
BACKintheDA
Apr 18, 2004 04:05 PM
Erik95LS
Dec 19, 2001 06:39 PM
