forgot..whats the size of the oil drain plug on a 97 civic again??
Old Aug 26, 2002 | 06:56 PM
sleeepy's Avatar
Default forgot..whats the size of the oil drain plug on a 97 civic again??
13?
[Modified by sleeepy, 3:57 AM 8/27/2002]
Old Aug 26, 2002 | 07:03 PM
Bleed Black's Avatar
Default Re: forgot..whats the size of the oil drain plug on a 97 civic again?? (sleeepy)
head or thread? the head is a 17mm I believe.
Old Aug 26, 2002 | 07:18 PM
sleeepy's Avatar
Default Re: forgot..whats the size of the oil drain plug on a 97 civic again?? (slowasshatch)
whatever the size that gets that thing off.
piscorpio's Avatar
yup
Old Aug 27, 2002 | 12:51 PM
sleeepy's Avatar
Default Re: forgot..whats the size of the oil drain plug on a 97 civic again?? (piscorpio)
dammit..its not right anyone know how to get that thing off with..trying to do my first oil change. thank youuu
Old Aug 27, 2002 | 12:55 PM
Get a few sockets (13-17mm) and put them on until one works.
Old Aug 27, 2002 | 05:43 PM
jweller's Avatar
you can get 90% of every bolt on a honda with 8,10,12,14,17,19 mm sockets/wrenches. If it's not 17, try 19, that would be the same size as your lug wrench in the trunk, at least on my accord it is. if it's not 14, 17 or 19, somebody changed it for a non honda part.
Old Aug 27, 2002 | 10:29 PM
Dudz's Avatar
Default Re: forgot..whats the size of the oil drain plug on a 97 civic again?? (jweller)
It's 17mm on my 99 civic
Old Aug 27, 2002 | 10:37 PM
Youre trying to loosen the large bolt directly in the middle of the oil pan correct? If you cant do that then I would recomend you hold off on doing your first oil change. I can just see you unbolting all the little bolts that hold the oilpan to the block
elmalouno
Apr 26, 2009 07:08 AM
n-line4
Apr 14, 2008 07:02 PM
Clairvoyant
15
Jun 21, 2006 09:42 AM
Mt3c
Oct 15, 2003 01:52 PM
