jacking her up
those arent tabs, they are pinch welds, jack up from the rad support and set your jack stands on the pinch welds behind the wheels, per the service manual
the "tabs" you would use on a 4 corner lift? there is no problem at all jacking a car from any of the 4 side jacking points
this is insane. you now are posting pictures of the very points i was talking about lifting the car from. bottom picture
dude....WHAT THE HELL ARE YOU TALKING ABOUT? When using a floor jack you jack from the rad support or the tow hook, not the pinch welds, because you run the risk of bending them with a regular jack that doesnt have the pinch weld insert. holy hell man i feel like im in preschool on here.
guys its not like im making this stuff up just for the sake of argument, im quoting the damn service manual for you on proper procedure so that you dont damage anything on your car accidentally.
damn, now i can take the top part of the radiator support and bend it by hand, same metal as the lower part of it. i personally use the front cross member. its much thicker and stronger to hold a car up on a jack.
ok, i found this. relates directly to integra's. http://www.g2ic.com/forums/showthread.php?t=22933
and for the op, i'm not trying to be an *** here, but i also found this for you. not a honda, but same concept.
http://www.ehow.com/video_1864_jack-car-safely.html
why are you getting so worked up? start condescendingly correcting people and you are bound to get witty responses.
The only reason you would jack it up in the front as spawn mentioned is because it is easier to put the car on jackstands when you do it that way rather than jacking it up from the tab.
I jack mine up on the flat spot behind and to the right of the tab and then set it on jackstands on the tab because my floor jack doesn't go high enough to use the front.
I love my Integra. My Cavalier would twist so much if you tried that, the door couldn't be opened with it lifted by only 1 jack point.
civic_tuned
Dec 2, 2003 11:14 AM
