jacking her up
Old Aug 31, 2009 | 07:09 PM
norcalB18's Avatar
Default jacking her up
Is it safe to jack up the front where the tow hooks go? DC chasis. If not were do u guys usually jack up the front of the car by?
Old Aug 31, 2009 | 07:24 PM
follie gatts's Avatar
Default Re: jacking her up
yes. sometimes my bottle jack doesn't work as well as my traditional car jack. there are also two tabs behind the front wheels.
Old Aug 31, 2009 | 07:26 PM
Spawne32's Avatar
those arent tabs, they are pinch welds, jack up from the rad support and set your jack stands on the pinch welds behind the wheels, per the service manual
Old Aug 31, 2009 | 07:29 PM
jhammond_82's Avatar
Reject Papi
i use the front crossmember. it won't bend.
Old Aug 31, 2009 | 07:37 PM
racebum's Avatar
the "tabs" you would use on a 4 corner lift? there is no problem at all jacking a car from any of the 4 side jacking points
Old Aug 31, 2009 | 09:15 PM
Spawne32's Avatar
i was unaware he was jacking the car up on a 4 corner lift
Old Aug 31, 2009 | 09:29 PM
racebum's Avatar
smart guy. if a car can be lifted that way on a 4 corner lift. why exactly could it not be on a floor jack?
Old Aug 31, 2009 | 09:41 PM
Spawne32's Avatar
what are you talking about?? i said i was unaware that he was talking about a 4 corner lift, i thought he meant a foor jack and stands, in which case the proper procedure is as follows.
Old Aug 31, 2009 | 11:42 PM
racebum's Avatar
this is insane. you now are posting pictures of the very points i was talking about lifting the car from. bottom picture
Old Sep 1, 2009 | 03:54 AM
sorry, mister terminology.
Old Sep 1, 2009 | 07:52 AM
Spawne32's Avatar
dude....WHAT THE HELL ARE YOU TALKING ABOUT? When using a floor jack you jack from the rad support or the tow hook, not the pinch welds, because you run the risk of bending them with a regular jack that doesnt have the pinch weld insert. holy hell man i feel like im in preschool on here.
Old Sep 1, 2009 | 08:16 AM
Reject Papi
why would you use the thin easily bendable metal of a radiator support?
Old Sep 1, 2009 | 08:33 AM
Spawne32's Avatar
because honda tells you to? guys its not like im making this stuff up just for the sake of argument, im quoting the damn service manual for you on proper procedure so that you dont damage anything on your car accidentally.
Old Sep 1, 2009 | 08:41 AM
I Still Love H.E.R.'s Avatar
Yeah, when we jack up cars at Discount we use the rad support or the tow hook in the back. But when using the lifts we just go straight up.
Old Sep 1, 2009 | 08:46 AM
Reject Papi
damn, now i can take the top part of the radiator support and bend it by hand, same metal as the lower part of it. i personally use the front cross member. its much thicker and stronger to hold a car up on a jack.
Old Sep 1, 2009 | 08:50 AM
Reject Papi
ok, i found this. relates directly to integra's. http://www.g2ic.com/forums/showthread.php?t=22933
and for the op, i'm not trying to be an *** here, but i also found this for you. not a honda, but same concept.
http://www.ehow.com/video_1864_jack-car-safely.html
Old Sep 1, 2009 | 10:22 AM
i jack my car up on the TABS behind the wheels with a bottle or normal plate car jack every time. i have never bent either TAB.
why are you getting so worked up? start condescendingly correcting people and you are bound to get witty responses.
Old Sep 1, 2009 | 11:54 AM
norcalB18's Avatar
haha thank you all for the replys. I was trying to get my car on 4 jack stands. It was fun reading ur arguments haha. Got it up now though
Old Sep 1, 2009 | 12:59 PM
racebum's Avatar
now we can all sit back and laugh at this little girl bitch fest on jacking up a car
Old Sep 1, 2009 | 02:15 PM
mrdeadman's Avatar
They let me pick
The only reason you would jack it up in the front as spawn mentioned is because it is easier to put the car on jackstands when you do it that way rather than jacking it up from the tab.
I jack mine up on the flat spot behind and to the right of the tab and then set it on jackstands on the tab because my floor jack doesn't go high enough to use the front.
Old Sep 1, 2009 | 04:21 PM
nsxtasy's Avatar
H-T Order of Merit
Yup. That's why most people call them "jacking points". (They're called "support points" in the service manual.) And yes, you can use a jack or a lift to lift the car from those points, as shown on page 1-9, the page before the page shown above. They are designed to support the weight of the car. You can even lift one side of the car from the front jacking point, with both tires off the ground, such as if you want to rotate the tires, or swap to winter tires or track tires. No problem doing that.
Old Sep 1, 2009 | 05:29 PM
TunerN00b's Avatar
I do so every auto-x. Lift one side of the car, swap both wheels, move jack to other side and repeat.
I love my Integra. My Cavalier would twist so much if you tried that, the door couldn't be opened with it lifted by only 1 jack point.
Old Sep 2, 2009 | 01:41 AM
jdmjoka's Avatar
DB squad #282
lmao
Old Sep 2, 2009 | 04:28 AM
95DC2GS-R's Avatar
Just use a floor jack under the transmission, or the the radiator..
Old Sep 2, 2009 | 11:07 AM
racebum's Avatar
floor pan is a good place too {don't laugh, i've seen someone do it }
ITR640
Oct 1, 2004 12:43 PM
Pompiuses
Sep 11, 2004 03:38 AM
civic_tuned
Dec 2, 2003 11:14 AM
GSblueRacing
Mar 28, 2002 11:16 PM
