Suspension & Brakes Theory, alignment, spring rates....
Squeaking Noise Front Right Wheel
Old Aug 31, 2009 | 03:16 PM
bopbop93030's Avatar
Default Squeaking Noise Front Right Wheel
I having a hard time figuring where this squeaking noise coming from. The noise is coming from the front right wheel are. When you pressed down the fender the squeak is there probably by the disc brake area, I doubt if it is the spring and shock.
These are the what is installed
GC w/ Koni yellows
Ingalls Camber kit front and rear
ST sway bar - I doubt it coz. the noise is coming towards the front and not from the inside.
I sprayed this morning with silicone lubricant everything I can think off in the front and yet the noise is still there.
When somebody gets off from the passenger side it squeals.
Help!
Old Aug 31, 2009 | 05:25 PM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: Squeaking Noise Front Right Wheel
you check the tie rod end??
Old Aug 31, 2009 | 05:53 PM
TunerN00b's Avatar
My GC extended upper shock mounts came with polyurethane spring isolators that squeak. OEM spring isolators are rubber. If you have them, could be the cause.
yes
Old Aug 31, 2009 | 07:20 PM
Don't have any isolators of any kind on my springs all around.
The thing is why is it, it only squeals on the pass side front.
Tomorrow I will jack up the car again and just dropped the front supported with a block of wood and jack and will try to find the source.
When the car is jacked up and no wheel there is no noise only when there is a wheel.
Old Sep 1, 2009 | 09:20 AM
Egezzy's Avatar
does this noise appear during bumps/drops or turning or both??
Old Sep 1, 2009 | 10:02 AM
Normal driving, yes there is sound but minimal but if someone who gets off on the pass side it will sound. The sound is like one of those bicycle horn that has a black rubber you have to press. like airhorn style.
No it does not make noise when turning.
Old Sep 1, 2009 | 01:31 PM
Egezzy's Avatar
so it makes that squal of a goose??
Old Sep 1, 2009 | 03:02 PM
OneManArmy's Avatar
Wheel bearing?
Old Sep 1, 2009 | 08:19 PM
danielfleenor's Avatar
i got the same prob. Im just lowered on HKS's **** is annoying
Old Sep 1, 2009 | 08:20 PM
ttt
Old Sep 1, 2009 | 09:25 PM
Egezzy's Avatar
do you guys have "aftermarket" bushings anywhere in your front ends??
Old Sep 2, 2009 | 11:30 AM
dragallmotor24's Avatar
Try lubricating/greasing your upper and lower ball joint...Sounds like the same issue I had on my DC. If that works, your gonna have to replace them both.
Old Sep 4, 2009 | 07:40 AM
siRone's Avatar
Could b the camber kit too. I know some of them r made with polyurethane. Ingalls FTL. I have the same ones.
Old Sep 4, 2009 | 08:02 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
sounds like the lower ball joint
Old Sep 4, 2009 | 09:53 AM
Been busy lately and I do not have time to take a look at it. Maybe this weekend.
Old Sep 4, 2009 | 07:59 PM
Egezzy's Avatar
also true. i was going to say the same thing but the noise described isnt exaclty the same noise mine make. lol. his was described as a nike squeeze horn. lol. those ***** are loud. lol.
Old Apr 22, 2010 | 08:45 AM
lazyxmofo's Avatar
Has anyone Found a solution for this problem? The same thing is happening to me. Squeaky when I push down on my fender and doesn't squeak when I take the tire off
Old Apr 22, 2010 | 10:21 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Most likely it's the upper control arm bushings. I had cheap aftermarket OE-replacement upper arms on my car and the bushings and ball joints all took a dump within a year. The front of the car squeaked soooo loudly when pushing down on the front of the car.
Try jacking up the front of the car, remove wheels, and unbolt lower shock fork and sway bar end links. Then move the suspension up and down freely to see where it squeaks.
I tried loosening the UCA bushings and then tightening them back down at suspension ride height, but that only helped for a few short days.
analyzer64
Honda Civic (2001 - 2005)
Sep 12, 2016 07:00 AM
SH4DY
Jan 26, 2009 03:08 AM
rivoe302er
Apr 3, 2007 09:09 PM
verbal
May 4, 2005 08:26 AM
redteg1
Sep 26, 2001 09:09 AM
