car has no power after fixing a fuse
Old Aug 31, 2009 | 01:24 PM
acuralovar's Avatar
Default car has no power after fixing a fuse
the cars a 92 integra i keep having stupid problems one after another..i just changed a fuse that was blown and fixed the wire that was melted from the guage cluster..before that the car had power but now . NOTHING. no power at all no noises and lights no nothing ..could it be the main relay ? i have a MMeter and the battery was ok and i was getting power at the starter and at all the fuses in the fuse box..any ideas
Old Aug 31, 2009 | 01:32 PM
TunerN00b's Avatar
Default Re: car has no power after fixing a fuse
Blown fuse and melted wire, sounds like you had/have a short.
You'll need to do electrical troubleshooting here, and identify exactly what shorted, and what else the short took out with it.
Old Aug 31, 2009 | 01:43 PM
acuralovar's Avatar
alrite heres the story i just put in a motor and connected everything but there was one connector that was broken (thermostat housing sensor) i must have plugged it in backward ...after everything was alset i put the termals on and noticed smoke come from the (TH) and my guage cluster. so i pulled off the termials checked out wat was goin on ...today i pulled my cluster and seen a wire melted onto another one so i undid them and taped them up and i swapped out the fuse that was blown. it was one of the bigger fuses (40)...after all that i put my cluster back and put on the termials and then here i am ...which is no power to anything ..battery is good tested it 100 times ..and its getting power to all the fuses ..
Old Aug 31, 2009 | 02:15 PM
tougetuned_ef's Avatar
wow that could be a 100 dif things. all you can do is start checking the power on every thing in that fuse box. unfortunatly you might just have to go new harness, new fuse box, maybe even new ecu. if you dont feel like really digging in thats your onlyn way. i put my xsi motor in my old ef. the electical problems unfortunatly cause me to just sell the whole damn car. minus the motor. kind of a mistake when i think back.
Old Sep 5, 2009 | 08:30 AM
acuralovar's Avatar
has anyone else had a problem like this with getting no power anywere?? my headlights also dont work..nohting works ..wat should i be looking at
Thepowderblue
May 23, 2012 02:30 PM
99hcdx
Jan 31, 2010 08:16 AM
DSM95DX
Aug 3, 2009 04:24 PM
Gvis420
Sep 18, 2008 06:28 AM
_Cyclone_
Jul 17, 2005 08:06 AM
