VS racing now services your engines needs
WE can custom build any motor package from wild to mild to conserative.
very competively priced.
We finally have caught up on our current demand of motors and are working on getting more help.
what do you mean by "build"?
does it mean, send you all the parts we've acquired to assemble and properly test them?
or does it mean, 'tell us which parts you want, and we'll get them for you and assemble everything as well'
and at what cost? from the minimal assessment to the extreme, ....?
give me a ballpark figure of what you charge.
need some kind of "pamphlet" listing the services or something, cause i'm still in the dark
edit: would you match or beat any competitor's prices?
[Modified by mntdewred, 5:04 PM 8/27/2002]
so basically pricing depends on what someone wants done?
have you come up with any kind of "packages" which starts out with basic stuff then gradualy growing higher with more advanced "packages"?
i'm also assuming you do machine work; port n polish, micropolish, balancing, knife edging, etc.....
yes sir we do. We have complete machine shop available to us.
The packages go from mild to wild. We determine what package is right based onyour needs. We only have two really flavors of packages right now that are predetermined.
That is for the GSR and the b18b/b20b motors
you should give us some price range or package discription. That would be super nice.... just so people know you prices and you won't be bombarded with tons of IM
up depending on what you choose
Full b18c job with pistons, JE,Wiseco,Arias with choice of rods Crower,Eagle,Pauter
Golden Eagle sleeved, balanced, new bearings, new oil pump, new water pump, bored, honed, assembled, deck checked, polished and balanced crank, New lower gasket set.
All for around 2500 depends crower/pauter are additional charges
Similar for dseries and H series.
How much for assembly Viren? Give us a ball park estimate so we can have an idea?
For example, say I choose you to assemble my block. I'd send you the sleeved D16, JE pistons, Eagle rods, factory crank, timing belt, oil and water pumps, complete Honda upper and lower gasket sets, oil pan, girdle, and I'd leave you to use the bearings and ARP hardware of your choice (in other words, you obtain the bearings yourself and charge me for them since I'd rather leave that up to a builder), what would I be looking at (roughly) for the assembly with all the parts I send you?
[Modified by VTC_slow_CiViC, 10:28 AM 8/29/2002]
I think I get it about the parts and machine work. But what about the block itself? Would I have to supply you with that or can you get that for me also?
if ther eis no maching work involved we would charge you 550 in labor to do your block with new bearing and arp head studs if maching is required we charge 60 hr
He's working on mine if damn usps ever sends my block.
