Pistons rings gone low idle.
I can feel air like pistons moving up and down at the top when oil cover is removed. The car will also idle at normal them drop and making a humming noise, and then it will idle normal. Check engine for a knock sensor. motor runs hot but dosn't overheat also is drinking oil in block ? Any ideas what the problem is getting ready to drop motor.
