Z6 Intake Mani Gasket Questions...
Old Aug 31, 2009 | 06:41 AM
Crossbreeder's Avatar
Default Z6 Intake Mani Gasket Questions...
Do aftermarket IM gaskets actually give you any type of power?
If so, how?
And if i were to buy one, what site/ brand/ price, ect.
And is it true that Y8 IM flow better, and would it be worth getting???
Thanks.
Old Aug 31, 2009 | 07:33 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Z6 Intake Mani Gasket Questions...
get a stock one. the hondata ones leak(im sure an arguement will follow this)
the y8 manifold is pretty good. use it over any other oem D series mani
Old Aug 31, 2009 | 07:39 AM
JDM_SOHC's Avatar
Y8 doesn't own like that... The Y8 has a better mid-flow, almost like the same increase you'd get from using a C.A.I. but the Z6 charts show better high end power than the Y8...
And I do always recommend OEM gaskets, unless you're insanely pushing your cars HP limits a stock gasket will be fine, just make sure when you take off the manifold and put the nuts on, you do it in a criss-cross fashion, along with torquing them right...
Old Sep 2, 2009 | 05:25 AM
Thanks for the info. Im hearing too much negative about the hondata gasket also
slob20ef
Sep 9, 2009 04:00 PM
welfarepc
Feb 23, 2009 06:03 PM
97grnrs
Dec 20, 2005 12:06 PM
egturbo
Jun 19, 2004 07:07 PM
fastcrxsi90
May 1, 2003 06:48 AM
