Brake Master Cylinder Issue
About 4-5 months ago I bought a 90-91 Civic EX 4Dr 15/16" brake master cylinder from one of the members on this board (along with brake booster and 40/40 prop valve) and i believe its junk. I have good pedal pressure coming to a stop, but slowly the pedal drops to the floor while sitting at the stop. No fluid is leaking from anywhere, so what I am thinking is the internal seals are allowing fluid to move past the piston. Anything anyone can recommend to check out first?
whe i did my rear disk conv i had a similar issue.
as you said it might be the seals of the pistons but i never heard of it going bad
in my case there was just air in the lines and a small vacuum leak in between the master cylinder and the brae booster. check that. did you touch the brake booster? kuz if you did make sure you have the gasket that goes between it and the fire wall
atmdc
21
Apr 11, 2007 07:06 AM
