sticky throttle body
Old Aug 31, 2009 | 01:02 AM
ILS_09's Avatar
Default sticky throttle body
My throttle body is sticky so I have to tap my gas pedal from time to time because it get stuck.How do I fix this?
Old Aug 31, 2009 | 01:15 AM
red96civicex's Avatar
Default Re: sticky throttle body
i would spray come throttle body or carb cleaner in there and itll clear it right up...your car will smoke black for a bit from all the stuff coming loose in the intake mani, but you might get better throttle response if you clean the IM out good enough
Old Aug 31, 2009 | 08:05 AM
jhammond_82's Avatar
Reject Papi
well put. ^ just try to keep the car running while your spraying stuff in there.
Old Aug 31, 2009 | 08:56 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Or do it right and take the TB off, and clean it thoroughly.
More then likely you have gunk right where the plate is.
Old Aug 31, 2009 | 11:21 AM
motormike40's Avatar
There's also a tiny screw on the bottom of the of the throttle body that stops the throttle. Mine is really stiff and sticky esp when I start it in the morning. If you tighten the screw so its longer it will help.
Type-Spaz
14
Jan 19, 2011 07:59 PM
Gsr.Turbo'd.Teg
May 7, 2007 03:59 PM
shooitzlinh
Mar 20, 2006 04:09 PM
NeoGSR
Feb 9, 2003 08:09 PM
vtecdc2
May 5, 2002 06:30 AM
