another wtf thread....
Old Aug 30, 2009 | 03:00 PM
bLu92bUbbLe's Avatar
Default another wtf thread....
listen to this......
went to take the bubble for a spin...break it in and break in the clutch...im cruising doin like 80....after about 15 mins of driving...i smell smoke...like oil is burning...so im like wtf...this **** has new seals and gaskets everywhere...as im pulling off the exit the **** cuts off...when i pop the hood i look the the timing belt...its still nice and tight...then i look at the cams...they all ****ed up...
then i break the head down (cam caps n cams) and notice the intake cam rail by the camgear is brown and dry...like its been burned...now im like wtf...the cams were grinding into the head...here r the pix...wtf ....i cant win...
YES!!!!!! i used plenty of assembly lube...and YES!!! i torqued everythign down right....
Old Aug 30, 2009 | 03:03 PM
Anon51's Avatar
Default Re: another wtf thread....
maybe no oil pressure or clogged oil pickup?
Old Aug 30, 2009 | 03:04 PM
just only that one side of the head was dry...everything else was oiled up
Old Aug 30, 2009 | 04:10 PM
slow96lude's Avatar
sounds like time for a line bore. It could be a case of having the belts too tight too.
Old Aug 30, 2009 | 04:20 PM
i think maybe the timing belt vwas too tight...
Old Aug 30, 2009 | 04:42 PM
deckster333's Avatar
holy crap never seen this before?!!? that bazaar
Old Aug 30, 2009 | 05:18 PM
i never saw...i never saw this b4 either.....**** sux...
Old Aug 30, 2009 | 06:41 PM
HondaGuy951's Avatar
timing belt was too tight....i agree it was pulling down too hard on the cam gear side of your cams causing that extra friction
Old Aug 30, 2009 | 07:17 PM
98greensi's Avatar
or also could have been if you put in new bearings you mixed the top with the bottom and plugged the oil passage
Old Aug 30, 2009 | 07:42 PM
93egSLEEPER's Avatar
looks like oil pressure was lost. i has something similar to that happen to me. did your oil light pop on? when you have no oil pressure that typically is what causes the cams to gouge the head like that.
Old Aug 30, 2009 | 07:52 PM
jdm_obsession88's Avatar
ouch that sux..id say it was the timing belt too.
Old Aug 30, 2009 | 08:04 PM
forcefedferio's Avatar
i agree
Old Aug 31, 2009 | 02:49 AM
damn...this sux....i burned up my head cuz i tightened the belt too damn tight...it was pretty tight too...after i did the belt i said to myself this may be too tight....but i didnt think there was a such as too tight
Old Aug 31, 2009 | 02:50 AM
no oil light...the pump n sensor are fresh...
yea i put new bearings...but i had that looked over after me by a machine shop...
Old Sep 1, 2009 | 05:09 PM
bump...
BDogggUT34
May 20, 2011 07:34 AM
DAchiko
Aug 25, 2010 12:45 PM
rorik
Sep 19, 2007 05:41 PM
nexgen91
Jul 31, 2007 07:08 AM
B18C_EJ8
May 22, 2007 12:08 PM
