what kind of hubs and axles on a crx hf,lsd hydro tranny b18
Old Aug 30, 2009 | 03:00 PM
bubba3369's Avatar
Default what kind of hubs and axles on a crx hf,lsd hydro tranny b18
im gettin the wrong answers from everyone.what axles and what kind of hubs needs to go on a crx ls vtec lsd hydro tranny? i have hf nuckles im changing them to crx si nuckles. i need to know what make,model,and year hubs and axels to make this car ride.im also having prolbems tring to get the shifter support on it need to be longer my shift link is hasport made for a b series swap it works but there is no where to mount the shift support bar.the crxs have 2 bars a shift linkage bar and a support bar do i need to call hasport to c if they make them or can i get 1 off a interga or something?please someone help me!!!!!!!!!!!!!!!!!!
Old Aug 30, 2009 | 03:11 PM
iheartteal's Avatar
Default Re: what kind of hubs and axles on a crx hf,lsd hydro tranny b18
the crx si knuckles will be fine. get b18a halfshaft and axles, the shift linkage has to be specifically for an ef with a bseries, you can make an integra shift linkage work but you have to cut and weld
Old Aug 30, 2009 | 03:29 PM
grog's Avatar
It sounds like you're just missing the bushings and hardware for the shift linkage. post a picture of what you have for the linkage. For axles you can use any 90-93 integra axles and half shaft.
Old Aug 30, 2009 | 03:37 PM
bubba3369's Avatar
Icon6 Re: what kind of hubs and axles on a crx hf,lsd hydro tranny b18
i have and 94 half shaft and 93 interga axles the prolbem is that they will not fit into a si crx hub but the half shaft and axle fit togther the half shaft is male on both ends and the driver side 93 axle has a male and a female the female fits into the half shaft... the only prolbem is i need to know what year hubs?and no i dont have a bushing and it is about 6 inches short from the tranny i can cut and weld but on the track that might break when im shifting .so will 86-89 interga hubs work with 93 axles
Old Aug 30, 2009 | 03:56 PM
Targa250R's Avatar
be professional
Umm, you can't use a '94+ Integra intermediate shaft with a '90-93 Integra left axle. The DA left axle is male and the DC intermediate shaft is male. You need to get either a DA intermediate shaft which is female, or a DC left axle which is female.
All '90-01 Integra right axles are the same, but you need to match the intermediate shaft with the left axle - both either '90-93 or '94-01.
DA knuckles will definitely fit into '88-91 CRX Si hubs, because it's the same setup that everyone else including myself is using for a B-series hybrid EF.
You must not have the parts that you think you do.
If you have '88-91 DX/LX/Si or EX knuckles, you use the hubs that you already have.
If you have HF/STD steering knuckles, you will need to get DX/LX/Si knuckles or EX knuckles.
It's not going to break unless you're the world's shittiest welder. How do you think shift linkages are made to begin with?
No.
Old Aug 30, 2009 | 04:06 PM
bubba3369's Avatar
my crx is a 1990 hf.so what u r telling me is i need si nuckles whitch my buddy is giving to me.94 interga hubs and 94 interga axels because my half shaft is a 94 both male ends and my tranny is a 94 .So the 94 interga hubs will they fit into the si nuckle because none of the axles that i have found will not fit in the si hub ?this is crazy so many people are telling me different things i just need to know what axles and what hubs to order tonight online thats all.
Old Aug 30, 2009 | 04:20 PM
Targa250R's Avatar
be professional
No.
'90-01 Integra axles (except JDM ITR) will fit into the DX/LX/Si or EX hubs. They will not fit into HF/STD hubs. What axles have you tried?
Old Aug 30, 2009 | 04:45 PM
bubba3369's Avatar
i found it 90-93 interga axles will fit into a si hub thanks
Old Aug 30, 2009 | 07:14 PM
BLOWNEF9's Avatar
Are you reading what is written here man? Listen to Targa.
If you are using the intermediate shaft from a 94 you need to use 94-01 axles. If you want to use 90-93 axles you need to use an intermediate shaft from a DA Integra. This is day 1 stuff and you are just making it way too complicated man.
10sec4door
Northeast (Sales)
Aug 4, 2010 04:46 PM
Fezzie
Aug 16, 2006 09:09 AM
trexb16
Nov 27, 2003 07:54 PM
The AntiRice
Dec 4, 2002 07:19 PM
Skunk2 RaceR
Jun 1, 2001 05:12 AM
