itr tranny vs...
gsr tranny with itr internal. thats possible right. i beleive the itr trannys are going for 1800 with a FD and lsd. if i get a GSR tranny could i put an itr FD (4.7) and lsd for cheaper than puchasing the ITR tranny with FD and LSD. i have some cash to spend and i am looking for a tranny for my ls/vtec.
tanx
tanx
the gearing will still be different with the gsr tranny even if you put a ITR FD.
i would recommend saving for the ITR tranny because:
a. lighter flywheel
b. tighter gears (even before a jdm or other FD installed)
c. LSD
i'm assuming you're talkin about the USDM ITR tranny which has a 4.40 final drive.
and when you have the ITR tranny, all that stuff is already installed...
which might end up saving you money/or future pain in the asses...
a. lighter flywheel
c. LSD
I have ordered a 98+ JDM LSD ITR Tranny(with the 4.7FD) from Brian, he's a good guy to deal with, it should be arriving this week, cant wait, just thought I would share, enjoy
Who is this brian guy?? I ordered a tranny from randd like 3 months ago and still don't have it. What is his screen name and are these NEW trannies or used???
.....why not order a '99-'00 si tranny and put the 4.7 or 4.9 final + lsd in there?
ATS all the way baby! (And cheaper too!)
thanx
hmm.. would that be as good as the ITR tranny if i put the ATS and LSD in it.?
thanx
hmm.. would that be as good as the ITR tranny if i put the ATS and LSD in it.?thanx
.....It will be much better!
I swear you won't be able to go back to anything lower.
Brian is the ****, im waiting for my toda clutch and flywheel to out my itr tranny on. Got my tranny 2 weeks after I sent him a check. We are on opposite sides of the US. b18c1_powered_si
I wouldn't go with the JDM final drive tranny unless you mean a US tranny with the JDM final already installed.
The JDM tranny does have a higher final drive but its gear ratios are different from the US in 4th and 5th gear. While 1st-3rd are great the gap between 3rd and 4th is off. Its not as tight as the US tranny (JDM 96spec). It would yield better gas mileage like this but that is not really a big issue. If it was only fifth that was changed that would be fine but 4th gear is still significant enough that it is used often under hard acceleration. Just my thoughts on the matter.
the si tranny is weaker than the type r tranny.
same gearing...heavier flywheel and
some shaft or something is physically smaller on the si tranny
*more prone to snap/break*
id like to know how u figure this. ATS FD $800, ATS LSD $900 on a good day, SI tranny $600 on a good day. sounds like over 2 grand to me. not even close to the 1600 u can get a JDM FD ITR tranny for from brian.
[Modified by baonest, 2:51 PM 8/28/2002]
NEW JDM ITR TRANNY 1800 shipped.....great price
used 99-2000 si tranny 600 used
itr lsd 400 used
itr final drive 450 used
installation 250
so you save 100 bucks....not really worth it if you ask me...just get the jdm itr tranny....
unless you have access to these parts for cheap....
i have under 800 in my si jdm final itr lsd tranny!! but i had parts laying around! and did the labor myself but it is NOT BRAND NEW!!
the diff is physically smaller, same size as a LS tranny. the flywheel stays with the block. it doesnt come off with the tranny so who gives a ****?? i wounldnt say its a weaker tranny because of the smaller diff.
rod- who's also planning on a tranny swap
cool i'm learning so basically i should get an Si tranny, quaife torque biasing diff, and toda flywheel...worry about the FD later on...
SPOON_BeIgHtEeNsEe
Dec 27, 2001 01:25 PM
