ls vtec lsd tranny prolbem with axle and hub help!!!!
Old Aug 30, 2009 | 01:59 PM
bubba3369's Avatar
Default ls vtec lsd tranny prolbem with axle and hub help!!!!
i have a 1990 crx hf with a ls vtec and a 94 gsr interga lsd tranny .i have a half shaft that is a male on both sides.my axles are 93 interga and i have hf stock hubs and hf spindles.what year axles and what year hubs and spindles do i need some 1 please help me im having people tell me so many different things thanks
bubba quinton
Old Aug 30, 2009 | 02:04 PM
DCRB's Avatar
Default Re: ls vtec lsd tranny prolbem with axle and hub help!!!!
you are going to have to change your hubs. any 88-91 dx/ex/lx/si knuckles will fit with no problems (ex hubs will require at least 14" rims due to larger brakes). integra knuckles will work but you have to get an alignment because the geometry is different.
Old Aug 30, 2009 | 02:12 PM
bubba3369's Avatar
so what year hubs and axles do i need?aND WHAT DO THEY NEED TO COME OFF OF ?SO U ARE SAYING THE HF NUCKLE WILL NOT WORK RIGHT?IS MY BRAKE CALIPER GOING TO FIT OR DO I NEED TO CHANGE IT TO???
Old Aug 30, 2009 | 02:17 PM
apekd's Avatar
you need to get (like DCRB said) DX/LX/Si knuckles. the HF and STD knuckles are TOO small for the axles to fit.
and dont type in all caps. It is annoying, gets people pissed of, and if you **** off the wrong mod you can get booted for a day or two.
apekd's Avatar
haha double post
try to find those knuckles and youll be set
Old Aug 30, 2009 | 02:22 PM
bubba3369's Avatar
i tried to put i 93 axle in a si crx hub and the hub is to small.will a 92 interga hub work and do i need 86-89 interga axles thats what iv been told but thatnks for telling me about the nuckle iv got one of them.
Old Aug 30, 2009 | 04:46 PM
beansandrice's Avatar
I got Dx hubs and 89 teg axles. Works very nice
Old Aug 30, 2009 | 06:41 PM
Crx Jimmy's Avatar
you can use the passenger side 93 integra axle, but with that mid shaft you need a 94 + driverside axle, I would recommend using 90-93 integra spindles, just use your upper crx/civic arms and get an alignment after
cb07
Apr 7, 2008 07:15 AM
onemore
Jan 9, 2008 03:51 PM
aznboi_2
Nov 3, 2007 06:12 PM
akb16
13
Sep 16, 2003 06:36 AM
litlekikr
Apr 20, 2003 10:05 AM
