Civic Randomly Turns Off
Old Aug 30, 2009 | 01:36 PM
1nv4d3r's Avatar
Default Civic Randomly Turns Off
Help! My 1993 Honda Civic randomly turns off when I drive. It has happened twice in the past two weeks. The first time I turned it back on instantly, the second time it didn't start for thirty minutes. Battery stays at 14+ volts and fuel is getting into the engine. I turn the key and it turns over but never starts. Then randomly it wants to start. I think it is electrical. My friend and I have been thinking it is something electrical, perhaps relays or distributor? Any information would be appreciated. Thanks.
Old Aug 30, 2009 | 01:38 PM
425_Booster's Avatar
Default Re: Civic Randomly Turns Off
any CELs? my guess would be crank angle sensor. tiny piece of dirt might be on there. other possibilities though too.
Old Aug 30, 2009 | 01:51 PM
1nv4d3r's Avatar
Alright, thanks for the information, going to check on it.
Old Aug 30, 2009 | 02:03 PM
Former User's Avatar
If you are saying that the fuel pump primes when the engine won't start, then test the igniter unit and coil in the distributor.
Old Aug 30, 2009 | 02:04 PM
Jimster480's Avatar
i dont think its the crank sensor. It wont turn the car off, it will just make it run like ****.
It could be a sign that your coil is starting to go.
Old Aug 30, 2009 | 02:46 PM
1nv4d3r's Avatar
hmm, thanks, going to go test distributor
Old Aug 30, 2009 | 06:09 PM
joelmatt89's Avatar
if it does it again and wont start check to see if your getting a good spark. This could be fun to diagnose since it seems like an intermittent problem
Old Aug 30, 2009 | 06:46 PM
94civic96's Avatar
like everybody else is saying it seems like a sure sign of a distributor problem
Joshua Parker
Aug 7, 2018 02:33 PM
dcalloway619
Jul 5, 2014 11:00 AM
mynameizstitch
Mar 17, 2012 10:55 AM
gs-R_swap
Sep 23, 2009 07:02 AM
Zion-I
Jan 24, 2007 07:34 AM
