HELP
Old Aug 30, 2009 | 10:40 AM
kingstonef's Avatar
Default HELP
Okay So heres a detailed break down on my story..
Bought a 1989 honda civic NO RUST and only a blown headgasket, And it's been sitting for 9 months.
So i tear it apart.. machine shop okays the head and block for levelness. and I get a new grafite headgasket. Put it in.. and the thing is a SNOT to start.
Get it started.. and she is smoking.. so i'm wondering WHY on F#(K are you smoking.. So i check my oil.. and it's oil.. i check my coolant and it's coolant.. i check my temp and it's running a little colder then normal*maybe 2 degrees*
So i figure out it's my lower spark plug gaskets.. So i take my rocker assembly off and put it back on* I DIDN"T MOVE OR CRANK THE CAR WHEN IT WAS OFF..
Now i put the rocker assembly back on.. and i do criss cross pattern on putting it back together.. torque her down.. then i do my valve lash and she won't fire.. JUST CRANK AND CRANK AND CRANK AND CRANK AND CRANK!...
What did i do wrong.. i'm going up the wall!
Old Aug 30, 2009 | 10:46 AM
garageEF's Avatar
Default Re: HELP
It could be many things, have you replaced a HG before?
Cam timing is correct?
compression?
Old Aug 30, 2009 | 10:54 AM
kingstonef's Avatar
Default Re: HELP
yah.. It was running intell i removed the rocker assembly and then reassembled it. something there is wrong.. what could I have done there to cause this..
Old Aug 30, 2009 | 11:23 AM
kingstonef's Avatar
Default Re: HELP
Anyone.. i'm gonna take the rocker assembly back off and see what i might have done wrong.
Old Aug 30, 2009 | 03:26 PM
kingstonef's Avatar
Default Re: HELP
Anyone please.. I took it all back apart and put it back together.. I get spark in 2 out of the 4 wires.. 1 is orange one is White. This is really annoying.. Please help.. the car also likes to have it's running lights on and it keeps blowing my insturment cluster fuse.
I got stupied champion wires and ngk itriuam plugs i'm pretty sure. There black as hell.. Maybe fouled?
Old Aug 30, 2009 | 05:46 PM
94civic96's Avatar
Default Re: HELP
ok if your car was running and not running now.... i would check your firing order if thats right put a spark plug in each spark plug wire have a friend try 2 start your car and check each one for spark if you dont have spark on each wire look at the components in your distributor(meaning youll have to buy something in the distributor) buttt if your spark is good check your fuel see if you have fuel pressure.... if not something from your fuel injectors to your fuel pump needs replaced....and also check all your fuses other ...you jus need to eliminate all the things that are ok and look into the things that are bad........and for your smoking problems if its out of the exhaust i would say its your rings most likely
Old Aug 30, 2009 | 06:13 PM
kingstonef's Avatar
Default Re: HELP
I went over everything to find my Dizzy **** the bed HARD
Looks like the 2 prong that goes into the cam.. has snapped inside.. so it catchs and then not catch.. and then it's sending a CEL and cutting my main relay..!
New dizzy time! 402,xxx on the original one
Old Sep 29, 2009 | 03:38 PM
kingstonef's Avatar
Default Re: HELP
Okay.. SO i went and got a new dizzy.. And it doesn't throw codes now.. But i'm wondering..could the cam have spun 180 degrees itself when the guy at the shop tighteed it to much and when he cranked it over it made ugly noise and could BARELY turn her had it so tight? There is fuel being sprayed out of the intake when cranking.
nemesis.442
17
May 7, 2012 12:34 PM
mar778c
Feb 4, 2007 07:14 PM
jackstands
Mar 13, 2005 08:54 AM
NERV
Sep 16, 2004 07:49 AM
