integra 99 in neutral all the time
Old Aug 30, 2009 | 10:29 AM
areede's Avatar
New User
Default integra 99 in neutral all the time
here the story driving the car everything is fine all of a sudden the rpm go up, so i check and it s in gear, pull to the side and try to go forward , it's always in neutral , standard transmission, why?
Old Aug 30, 2009 | 10:59 AM
gsrvong's Avatar
Default Re: integra 99 in neutral all the time
You might be low on transmission fluid, causing it to slip. Or a bad clutch. Maybe your gears just feel like they're always in neutral because you need new shifter bushings. I don't know much, but you can start checking these things.
ludesrv
Honda CR-V & Element
Sep 1, 2022 09:42 PM
farikanok
Jan 5, 2009 09:03 PM
EJ8chu
Oct 28, 2007 02:19 PM
bsemaan
Dec 26, 2004 05:50 AM
02 coupe
Jul 31, 2003 11:21 PM
