low rpm studer ?? b16a ? help
Old Aug 30, 2009 | 08:34 AM
krysted9354's Avatar
Default low rpm studer ?? b16a ? help
well i bougth a swapped b16a2 running obd0 everything is nicely done knock sensor is wired in and vtec is working !
but in every gear ,if i litely press gas and hold it the car will studer feel like the ebarkae is on but then if i give it gas its like i would let of the brakes and go. lol
??is it mabey because i advanced the dizzy?
since then it is doing it more ? thanks fr help
Old Aug 30, 2009 | 05:04 PM
Default Re: low rpm studer ?? b16a ? help
Old Sep 1, 2009 | 07:58 AM
ANYONE ?? like if i hold gas lightly the car will feel as it is getting not enought air and studders then all the suden jurke of power and back to normal ??
is it because of the blox intake mani and srtock throttel body ?
Old Sep 1, 2009 | 08:38 AM
dephtone's Avatar
I would check for a vac leak at the throttle body first.
Any codes?
You may need to recheck to make sure the timing is correct also.
Old Sep 1, 2009 | 03:16 PM
timing is good but itspopping the 2 3And its a no leaks but itsd blox amni and stock tb ?
Old Sep 1, 2009 | 05:09 PM
~sp33~'s Avatar
EFB055
Throttle cable adjusted correctly?
I'd work on clearing those codes.
B16tyler422
Jun 19, 2007 03:05 PM
Kool305
May 19, 2005 01:15 PM
handa
Apr 5, 2005 05:53 PM
junya16
Aug 1, 2003 12:36 PM
97itr86
Mar 15, 2003 08:45 AM
