C16 vs. Q16 vs. VP Import?
i love import, but who can afford it.
q16 seems to make a difference in some cars, and not in others. seems to be pretty corrosive in some applications. for a long time there was no warning labels on the containers, but now they have a warning label that tells you to drain it out of the car like you would with methanol.
C16 is tried and proven. ever since Q16 came out, i dont think ive had a single car come to the dyno that had C16, everybody has switched to Q.
I've found Import makes more power then q but too expensive
there's some other fuels out there that claim they make more then
Import. One of these days I'll test them
found this amusing.
This is right from the VP website!!!
Q. Is Q16 appropriate for superchargers or turbo applications?
A. This fuel is the nuts for intercooled applications. We're seeing huge increases in these applications. I haven't seen any issues with detonation when they follow the 6% rule. This is richen your fuel system 6% over C16 (which is the fuel 90% of these applications are using now) and you should be close to the air fuel ratio you were at before the Q16. This is where Steve Petty (Dyno master) picked up 107Hp to the tire on a twin turbo 588 ci application. The Q16 isn't responding as well in non-intercooled applications. I recommend that in these few instances, you should stay on C16. Heck, most of these applications have enough HP as it is.
I've tuned three completely different turbo cars, (before and after) that switched over to Q16, and using the recommendations from VP, picked up a lot of power. So now, all the locals that I hang with, use Q16. Also to note, on the 2.0L engine, I noticed quicker spooling as well. I can only guess that the increased exhaust volume made the turbo spool up quicker. The bigger engines and turbos had no noticeable decrease in spool times. The two V8 engines had remote mounted A/W intercoolers, and the 2.0L engine had a typical air/air front-mount intercooler.
Anyone know if I can throw the unused Q16 in my street car, mixed with 93 octane?
found this amusing.
my car doest really make any more power above 11.5:1 run it at 11.5 and 12.5 and it will be with in 5whp on the dyno. every car/motor/set up is different though
my question i guess is if you were to tune to 13.0 on Q16 then leave it alone and run C16 what would the af's be without changing the map? my guess would be according to the 6% they say it takes to run the q16 would mean the same map on c16 would be too rich? like in the 10.50 range??
Run what you are tuned on, remember timing values will change with different gas also. Its not all about the 6%.
i just did an evo and it seemed to run the best at about 11.8 to 12.0 but the owner was told to run at 13.0. we ended up running about 12.2, a bit leaner than i felt needed for optimum power. now if i run c16 in the same setup will it be too rich?
what are your egt's like ? I agree q16 is not happy running mid 11 afr's..... I like c16 for most customers cars, you can make good power and for a lot of people that dont pay attention to maintance of there fuel system it is safer . But import smells the best....
My egt's are pinned at 1745 (max on the racepak sensors) as soon as I click into 3rd gear. I am still being a little girl with the timing. That is part of it but I scared to go too fast. lol
