jdm gsr help!
Old Aug 30, 2009 | 06:11 AM
b18buck's Avatar
Icon3 jdm gsr help!
91 ef si b18.. so i took my valve cover off yesterday to paint, cleaned everything off right and reassembled. today when i leave for coffee car does not start and back fires.. sooo my stoner *** realizes i switched 2 and 4, still no start and backfiring. now i have pulled plugs and wires and there is oil in the plugs? cleaned that up and blew out with air hose and still no start. any suggestions ht??
Old Aug 30, 2009 | 06:47 AM
Targa250R's Avatar
be professional
Default Re: jdm gsr help!
Replace the valve cover gasket and the spark plug tube O-rings like you should have done the first time you pulled the valve cover.
Pull the plugs to allow any residual oil to drop into the combustion chamber.
Old Aug 30, 2009 | 06:48 AM
93excivic's Avatar
did u check if theres any spark and check the fuel and the timing
Old Aug 30, 2009 | 07:01 AM
b18buck's Avatar
i did pull the plugs.. and the valve cover gasket and all o rings are only 2 wks old, so i cleaned them all very good scraped off all rtb with razor off of head, do i really need a new one??.. and the distibuter or anything for timing was nvr messed with so how could it have gotten out of time?
Old Aug 30, 2009 | 07:10 AM
b18buck's Avatar
oh and checking for spark now, plugs and wires less than a year old tho
Old Aug 30, 2009 | 07:44 AM
b18buck's Avatar
Ok all have spark...
Old Aug 30, 2009 | 09:58 AM
b18buck's Avatar
alright common ht i need help... jst did all new gaskets and still it wont run, any other suggestions?
Old Aug 30, 2009 | 11:32 AM
D16SiHatch's Avatar
if all you muffed up was the firing order then its quite likely that order is still incorrect. triple-check that ****
ilikeric3
Sep 21, 2006 08:41 PM
luv2cruz
Sep 13, 2004 05:33 AM
armrslr
Feb 10, 2004 07:30 AM
lke2drvgsr
Sep 29, 2003 07:25 PM
