Suspension & Brakes Theory, alignment, spring rates....
will 94 integra struts work on a 93
Old Aug 29, 2009 | 08:33 PM
jdmf23accord's Avatar
Default will 94 integra struts work on a 93
i have a 93 integra and im in process of buying struts and springs. will 94 integra struts and springs work on a 93. if they wont work can you tell me why. thanks
Old Aug 30, 2009 | 07:01 AM
Default Re: will 94 integra struts work on a 93
anyone
Old Aug 30, 2009 | 09:13 AM
Egezzy's Avatar
Spongebrad Squarepants
only input i can give is my buddy put a da setup on his eg that was sitting(not driven) and the shock rods extended out incredibly farther than normal.
hope this helps somewhat.
Old Aug 30, 2009 | 10:33 AM
92civic_hatch's Avatar
one of my friends top bolts on the back strut stripped i had some extra da struts so we used those on the back of his car. worked fine. i know that the a arm piece on the front struts is too small in diameter to fit a dc or civic shock on it. so as far as i know it would work unless you switch those a arms. someone correct me if im wrong. you could also try posting this in the integra section
Old Aug 30, 2009 | 11:23 AM
Egezzy's Avatar
that is correct. my buddy used the da forks. so obviously this would have to work the opposite.
Old Aug 30, 2009 | 12:56 PM
racebum's Avatar
never tried it but i sold a set of 97 oem shocks to a kid the other day for his DA. he said with the DA forks they work. got me what the results are but he sounded pretty confident
Old Aug 30, 2009 | 01:56 PM
JNocon's Avatar
DC2 forks.
EG forks.
Old Aug 30, 2009 | 05:50 PM
k ill let yall know
Old Aug 31, 2009 | 02:49 PM
bks84's Avatar
Loved
why not buy the suspension thats made specifically for your car?
Old Sep 8, 2009 | 05:04 PM
because its a winter beater and the 94 stuff is cheaper as a package deal.
also do anyone know why the front sits a good amount higher than the rear. is it because of the 94 integra front forks.
Old Sep 8, 2009 | 07:31 PM
JNocon's Avatar
x2. And probably less headaches, too!
Old Sep 8, 2009 | 07:38 PM
like i said its a winter beater and was cheap
Old Sep 8, 2009 | 10:57 PM
2.0_DX's Avatar
New User
Correct me if I am wrong, but I believe the only major difference is that the DC/EG shocks and struts are a bit longer than those on an EF or DA.
bowdown201
Sep 19, 2007 09:09 AM
93civicexthug
Suspension & Brakes
Feb 13, 2007 07:12 AM
mikes99si
Suspension & Brakes
Aug 10, 2005 02:56 AM
