Help! High Pitched Whining From Engine
Old Aug 26, 2002 | 04:50 PM
JLange's Avatar
Default Help! High Pitched Whining From Engine
I got in my car tonight and when i started it up, it sounds like air hissing badly from the engine, near the front right side? does anyone know anything, a complete guess of mine would be the timing belt
Old Aug 26, 2002 | 05:05 PM
JLange's Avatar
Default Re: Help! High Pitched Whining From Engine (Lord Titus)
its on the drivers side, i do have abs, it sounds like a loud tire deflating almost, it happens when i crank the car up
Old Aug 26, 2002 | 05:46 PM
VTECorona's Avatar
Default Re: Help! High Pitched Whining From Engine (jtintegra)
Could be a loose altenator belt. See if it gets worse with ur AC on. I had the same problem, I brought it into the dealership, they checked everything and couldnt find anything wrong, noticed the alt. belt was a little loose, tightened it, no more sound :D.
Old Aug 26, 2002 | 05:52 PM
JLange's Avatar
Default Re: Help! High Pitched Whining From Engine (97RedTegGSR)
i just got in from listening to my car, and checking it out with a flash light, its dark here, but anyways it sounds to be like belt hissing almost, a little in front of the radiator. any ideas?
Old Aug 26, 2002 | 06:01 PM
mugenracer's Avatar
power steering pump/belt is in that general area.
Old Aug 26, 2002 | 06:03 PM
JLange's Avatar
Default Re: Help! High Pitched Whining From Engine (mugenracer)
i dont think its the power steering because it doesnt make more or less noise if i turn wheels
Old Aug 26, 2002 | 06:05 PM
hybridreams's Avatar
i can almost guarantee its a belt, just not sure which one. I'm having the same problem, just a softer whining type noise. Gonna have it checked out when I get my tranny worked on though.
Old Aug 26, 2002 | 10:03 PM
ExtremeImportRacer's Avatar
Default Re: Help! High Pitched Whining From Engine (hybridreams)
i know for a fact that its one of the belts. i had the same prob when i got all my belts replaced took it back to the shop and they fixed that belt, but they didnt tell me which belt
Old Aug 26, 2002 | 10:36 PM
JiggyKooAndy's Avatar
turn your AC off. haha j/k. yea, it's a belt, which one? who knows. take it in.
Old Aug 26, 2002 | 11:14 PM
RicerRacing69's Avatar
Default Re: Help! High Pitched Whining From Engine (JiggyKooAndy)
HAHAH.
But if you have intake and your filter is dirty it will cause a load whistling noise at idle and stop when over 1500 rpms. Get some K&N filter cleaner for like 9.95 and your set.
Old Aug 27, 2002 | 06:11 AM
X2BOARD's Avatar
Default Re: Help! High Pitched Whining From Engine (RicerRacing69)
Is it a whine ? Could be a damp/wet belt too. Hitting it with some WD40 would stop it... (if that's your problem.)
X2
MrsR
16
Aug 24, 2013 06:37 AM
CandyMamaRy
Jan 25, 2011 02:38 PM
stolen4drteg
Jan 4, 2005 04:13 PM
ek2k
Nov 26, 2004 02:09 PM
shermanator
Feb 14, 2004 10:58 AM
